Old 04-19-2014, 09:37 PM   #1
Tucker2's Avatar
Weird problems....door and window pre-ignition.
OK....car has randomly started acting odd with the windows and door shutting during while off/prior to start.
Started with the passenger door refusing to shut. After some experimentation...using the key fob to lock and un-lock the door fixed things.
Today...the drivers side window adjusts itself UP prior to closing the door, so you can't close it. Playing with the interior door handle or manually rolling the window down a bit 'fixes' things.
Any ideas? Running great other than this randomness.
Current: 981 Cayman
Former: '02 BS and '08 C
Tucker2 is offline   Reply With Quote
Old 04-19-2014, 09:41 PM   #2
Multi-Boxer Driver
Deserion's Avatar
Sounds like a bad door microswitch, IMO. If the interior lights go out when the window goes back up, then definitely it thinks the door is closed.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 04-19-2014, 09:50 PM   #3
Tucker2's Avatar
Thank you...I will watch for that and also search for door micro switches. Cheers.
Current: 981 Cayman
Old 07-05-2014, 10:54 AM   #4
Did you figure out whether it was the microswitch or something else?
My passenger door is doing the same thing yours was -- window dip to allow the door to open, but immediately goes back up when the handle is released and before the door is closed.
I'm making an appointment with an indy for other items, but I would want this checked out / fixed as well.
MacGrad is offline   Reply With Quote
