Old 04-13-2014, 09:10 AM   #21
The Radium King's Avatar
i thought jdm flares were kinda cheap too, but after some looking around they can be done to look pretty ok ...
Old 04-13-2014, 12:30 PM   #22
I'm confused as to why you think you will need more than a 285mm wide rear tire (which is easily fit without going wide body in the rear)? If you are worried about straight line traction, install an LSD. Installing a "bigger wing" isn't going to do anything for traction unless you are going at speed around a race track. If you just want wide body because you like the way it looks then I can't fault you for that, but don't try and justify if as a performance modification on a street car. This is coming from somebody who daily drives a Boxster with 370whp, with an LSD, on 275mm rear tires (NT05's) and I only have mild traction issues in first gear. Also, is your car a 6speed car? If not, traction loss might go a long way to preserving the weak 5 speed transaxle.
kcpaz is offline   Reply With Quote
Old 04-13-2014, 05:37 PM   #23
Fair. Wideboy because I like the look, and can help justify it as performance. Same with wing :P
I'll be using a Boxster S 6 speed.
99 Porsche Boxster 986 3.8
85 Toyota Corolla AE86 F20C
12 Honda Accord
16 Mercedes C450 AMG
22 Tesla Model X Plaid
Old 04-14-2014, 10:49 AM   #24
woodsman's Avatar
Whatever you do- stay away from 'House Of Kolour'!
