-   -   Any top replacement DIY'ers out there? (http://986forum.com/forums/boxster-general-discussions/51557-any-top-replacement-diyers-out-there.html)
truegearhead 04-08-2014 09:27 AM
My top window finally cracked. It looks like you can get a replacement for 300 on eBay but according to Pelican it takes 16 hours to replace!! 6 more hours than it would take to remove the engine. I feel like I could widdle a top of a wheat in 16 hours, what could possibly take that long. Has anyone done it?
driftguy 04-08-2014 10:07 AM
Yes I did it. Yes it takes a long time. 16 hours is a bit high. It's relative really, it is not just bolting a new anything on and checking torque. It's an art, and takes a bit of skill to get done quickly.
driftguy 04-08-2014 10:11 AM
Oh, spend the extra money on the glass upgrade. Absolutely worth it.
Eric G 04-08-2014 11:53 AM
I did mine in a day and at best taking my time I was able to get through it in about 5 hours. Just a note on going with glass if you have an earlier model Box the glass can limit your ability to access your engine as comfortably as you can with a soft top.
Now with that said, there are a couple of parts you want to order before you start your project. You will want to have these in place:
left slide 986.561.669.03
right slide 986.560.670.03
right clamping piece 986.561.559.01
left clamping piece 986.561.560.01
pins 986.561.597.00 (get 2)
Note: I found that I was able to salvage most of my older tops parts which fit better in the new top than the replacement parts...but that was me. You will break a pin, so while it suggests 2 get 4 their cheap. Here is a really good how to thread from Pelican. I used this along with Mike's webpage instructions. End result is I have a perfectly tight top.
This is the site you really want to study:
https://sites.google.com/site/mikefocke2/replacingthetop-adiy
Here is his main page:
https://sites.google.com/site/mikefocke2/mikesporscheboxsterwebpages
Here is Pelican's
Pelican Technical Article: Boxster Convertible New Top - 986 / 987
Good luck!
