Oil Change 2001 Boxster S
Rather than spending $225, I changed the oil in my car today. Very easy and highly recommend it. Used Mobil 1 0W40 (Walmart 5q jugs). On another site, someone recommended the Italian Tune Up and I did that yesterday.
The car has never run better....! Thanks for the help!:cheers: |
Good for you: doing your own maintenance is definitely satisfying. Just make sure you didn't overfill the oil; check the dipstick after the car has sat overnight.
If you do over fill, removing the oil filter will get rid of 1/2 quart at a time.
You have to reinstall and run the engine before you can remove the next half quart, so the engine can refill the oil filter. |
Just purchased a 2003 Boxster S, 19000 miles with automatic tranny. What type oil is recommended?
OMG there are numerous posts on the topic - just do a search. Many use 0W-40, but there are a multitude of opinions.
Sportscarguy,
What is the Italian Tune-up? MNC-I |
| All times are GMT -8. The time now is 09:41 AM. |
