-   -   Harnesses infos (http://986forum.com/forums/boxster-general-discussions/51232-harnesses-infos.html)
The French Dude 03-19-2014 05:29 AM
Harnesses infos
Hi everybody, I would like to know if it's possible to fit a Harness with stock seats in 986 Box?
Do I need to do some modification on the car?
And finally what kind of harness I have to buy?
Thank you!
thstone 03-19-2014 05:55 AM
It is not recommended to use a 5 or 6 pt harness with the stock seats. The problem is that the sides of the stock seats are curved which can allow the harnesses to slip down off of the drivers shoulder. Also, you'll need a seat that has a hole in the middle of the bottom of the seat for the sub belt to mount under the seat (which stock seats do not have and it is not recommended to simply route the sub belt around the front of a stock seat).
In order to use a 5 or 6 pt harness properly, a seat with holes in the back are typically required so the harness has a "straight run" from the mount through the seat and over the drivers shoulders. GT-3 seats work great and there are many aftermarket seats which will also meet these requirements.
In regards to mounting the harness, the stock Boxster roll hoops will work fine. You'll also have to add floor mounts to the sides and under the seat.
I use a Schroth harness in my race Boxster but there are many harnesses available and any good manufacturer will offer something that should work.
The French Dude 03-19-2014 06:03 AM
Thanks!
And does the 4 point will fit ?
thstone 03-19-2014 07:39 AM
Originally Posted by The French Dude (Post 391658)
Thanks!
A 4 pt harness will have the same issues as a 5/6 pt harness in regards to falling off the shoulders using the stock seat. Hence, it is not recommended to use a 4 pt with the stock seat either.
With the correct seat, a 4 pt harness will work but if you're going through the cost and effort of replacing the seat, you might as well get one that has a sub belt hole so you can use a 5 pt harness. This will provide add'l safety by keeping the driver from sliding out from underneath a 4 pt harness.
The French Dude 03-19-2014 12:06 PM
Ok thank you!
