-   -   Preventative maintenance thread.. (http://986forum.com/forums/boxster-general-discussions/51023-preventative-maintenance-thread.html)
Timco 03-04-2014 06:11 AM
Based on your personal experience, what should every Boxster owner go out and do this week or even today?
My input is to simply take the cover off your front & rear trunk latch and check the cable connections for fraying. Big hassle if one breaks. Easy to fix.
RawleyD 03-04-2014 07:28 AM
Go out and drive... like, really drive it!
For at least an hour
healthservices 03-08-2014 10:47 AM
As preventive maintenance, I think it is best to be safe and replace the car every 5 years with a new one... :rolleyes:
rick3000 03-08-2014 11:34 AM
There are a few items that have been redesigned due to issues with the original design, these things are worth checking:
-Make sure Coolant cap is newest design, PN 996.106.447.00
-Check Gas Cap for cracks on the o-ring
-Check Convertible Ball End Joints, if red replace with newer ones (not metal ones)
-Check Convertible Transmission Cables for stretching and replace with newer ones (mostly 97-99)
Some other things:
-Clean Drains, especial behind the driver's seat. Clogged drains can cause water to get under the driver's seat which can make the very expensive computer there fail.
-Clean the Throttle Body
-Reroute the frunk release cable to the tow opening (or elsewhere if you are savvy)
-Clean your radiators (requires removing the front bumper)
rocartfe2 03-08-2014 12:09 PM
Cleaned the radiators last weekend. Put a new radiator cap on this morning. Took it for a 2 hour drive with the top down on a twisty road in VA. Preventive maintenance done for me and the car.
RandallNeighbour 03-08-2014 01:09 PM
Replace the trunk shocks and wiper blades!
