Brake Fluid Flush! DIY or Dealer??
Hi everyone, Im the new owner of an 01 Boxster. Before purchasing the vehicle I did take it into Porsche for a Pre-Purchase Inspection and the only recommendation was that I have the Brake Fluid Flush done as part of the 30,000 mile service. I was wondering if I need to go with Porsche Brand Brake Fluid or are there other brake fluids that are readily available at the local auto parts store that are recommended and safe to use?? Additionally, what is involved with doing the flush and how difficult is it??
ANy web links for a DIY fluid flush would be greatly appreciated :) Thanks! |
Hi, A Flush is recommended every 2 years. Brake Fluid absorbs moisture and this can significantly lower the Boiling Point of the Fluid leading to soft, spongy, ineffective Brakes. Also, this Moisture will corrode the Brake System and it's parts, especially expensive with ABS. But, in addition to becoming moisture laden, Brake Fluid (primarily Glycol esters) will react with the metal in the system, Copper in the Brake Lines in particular. This reaction leaches Copper Ions from the metal which will react with the Oxygen and attack the Ferrous parts. ABS increases this effect because unlike Standard Hydraulic Brakes, where the Fluid basically works in a Fore and Aft movement (Like a cable in a sleeve), with ABS, the Fluid is circulated throughout the system. The contaminates are also circulated through the system and consists of iron or rust particles. The ABS Valves are especially vulnerable to this foreign matter. You should use the Porsche recommended Fluid and Power Bleed using Porsche's recommended procedure. Not too difficult and you will save some money. But, if you're unsure of when the last flush took place, I would recommend buying twice the normal amount of Fluid and flushing it completely. So, a small initial investment for the Bleeder - $75 will be needed and it will help greatly to have an assistant. There are lots of links for How To's out there. Here is a pretty good one: http://www.europeantransmissions.com/Bulletin/DTC.Porsh/POR%20Model%20986%20Brake%20Bleed%20Procedure.pdf Hope this helps... Happy Motoring!... Jim'99 |
When I had my PPI done they also said to have the brake fluid flushed. Your explanation gives a good reason for doing it. HOWEVER, I would like to point out that my 14 year old Miata with 130,000 miles on it never had the fluid flushed and never had a brake problem. I can say the same for my 16 year old Mercedes (one of the original ABS cars). As a matter of fact, this Porsche is the first car I ever owned that I have heard the recommendation to change the brake fluid so frequently. Why do Porsche's need this more often than other cars?
Considering the costs and danger involved with NOT flushing your brake lines every two years, I'd say it's certainly a good preventative measure.
Now about doing it yourself, I would imagine it's no harder than any other car. If you're up for it and willing to buy the tools necessary, you'll find that working on your boxster isn't any harder than any other car when it comes to brakes. Replacing the pads is really simple! Let us know what you decided to do... do it yourself or have a shop do it. |
Hi, Without ABS it isn't as critical, but still very critical. Porsches don't need it more often than other cars, they all should be changed every 2 years. The SAE did a study of New Cars 18 mos. old. They found the moisture content averaged 4% with a low of 3% and a high of 7%. With DOT 4 Fluid, a 4% Moisture Content lowers the Boiling Point of the Fluid to about 218 Degrees F. To put this into perspective, this means you're only slightly better off than if you ran pure water in the system. You may not have thought you needed it, but I'm certain that your maximum braking efficiency was severely reduced. Not to mention, that your Brake Hardware was probably excessively worn because of this. It's true you may have a Car for a lifetime and get away with it, but that still doesn't mean it's a recommended practice. It's just as critical as an Oil Change, maybe more so considering the safety implications. It's a pain to do, but not really too bad and it's not too expensive, much less than replacing a single Brake Component... Happy Motoring!... Jim'99 |
Very easy DIYer Project. Can be a bit messy at first but after caliper number 2 you will have it down! The Boxster was my first brake flush. Used just less than 1 liter of fluid and bought a Motive power bleeder to do the job. This way you won't have to mess with pushing in the brake pedal. :cheers:
rteichman, Mercedes recommends this same 2 year service. With a coupon, Mercedes charges $89. We have it done religiously. Small price to pay every two years to stop properly! And protects against a costly ABS repair. |
Is the motive power bleeder better than just bleeding the brakes by pumping the pedal and having a little help from a friend? I thought the power bleeder was only for folks that truly "do it yourself."
I say get one...no friend needed! Super easy to use. Fill with fluid, pump to correct pressure, attach drain hose to bleeder valve, slowly open valve and watch old fluid just rush out!. Close valve. Move to next valve. Get the correct order of bleeding by doing a search and the correct pressure for the bleeder before starting. Have rags handy to immediatly wipe any little drips you encounter. Your friend can then have a beer and watch instead of being under your dash! :cheers:
I'm not arguing against doing it, just relating my experiences with other cars. Rob |
My Mazda 929 has 199,000 miles and the original brake fluid. I should probably change that lol. The boxster gets all the attention.
928 Specialists has the Motive power bleeder for the best price I've found ($39). Just search "motive" on their site and you'll find it. It fits all Porsche models (except maybe a 40 year old 356). |
A little annoyance with the Motive Bleeder is the brake fluid reservoir cap can't just be screwed on...you need the screw the entire bottle as you screw or unscrew the cap. Did I do something wrong last summer or is there a workaround? :cheers:
I agree the stock Motive is a Pain. But, there is an alternative. There is a swivel Cap you can add which eliminates the issue entirely. Motive sells it for $38.00, but I got mine here for $25...: http://www.zimsautotechnik.com/acatalog/Metal_Swivel_Cap_for_Motive_Products_Power_Bleeder .html Hope this helps... Happy Motoring!... Jim'99 |
Does anyone know of any local shops like Napa,Kragen etc. that sell Ate Super Blue brake fluid over the counter?
http://www.tweeks.com/shop?frame=8.2300 |
Thanks for all the great tips and recommendations guys. I think Im gonna definitely DIY this one on my own and once again take great pride in keeping a little cash out of the dealers hands for now. I was originally going to go with the "using a friend to push the pedal method" however with the apparent ease and affordabilty of a power bleeder it seems like a worthwhile buy to me!
While Im at it, a totally off topic question....is there any sort of a particular oil filter wrench required for me to removed the plastic filter cup on my boxster?? I have seen a couple different ones advertised on ebay but Im hoping that one of the standard jobbies from a parts store might do?? Once again thanks for the help! Jeff. |
There are several on the Market. The thing to remember is that it needs to be 74mm and have 14 flutes or sides. The Filter s/b Hand Tightened, so I just use a strap wrench, works great. The last thing I need is another job-specific tool in my already overflowing Tool Chests. Hope this helps... Happy Motoring!... Jim'99 |
IMO, you'll still end up doing your last caliper with the "friend pumps" method. Why? The Motive keeps the fluid reservoir filled to the absolute top - you'll want to drain it down a bit so it falls at the max fill line. Easiest way to do this is to pull the Motive when doing the last side of the last caliper.
One other caution - take off the pressure from the bleeder if you are doing a pads change at the same time or for any reason you feel the urge to swing the caliper off the disc. There is no way to stop the caliper from traveling too far with just human hands (or the tools you will have at your side) once you notice it happening under the pressure from the Motive bleeder. Ask me how I know... :rolleyes: |
LOts of excellent and helpful tips in this forum related to the brake flush....A couple of gents have recommended bleeding the clutch as well as it is apparently supplied by the same reservoir. I actually had no idea that this was the case and I am wondering now what is involved in bleeding the clutch??? Where is the bleeder port and how should I work this is with the 4 wheel brake bleeders?? Once again, I consider myself decently handy around the vehicle...however I've never done a clutch fluid flush and most definitely wanna keep out of the stealership for this one!
Thanks. Jeff. |
Jeff, Here is a copy of a post I made the other day to answer this very same question from Adam. Hope it helps... Hi, It's simple and if Flushing/Bleeding the Brakes, you're already halfway there. The Slave Cylinder (at the upper left of the Tranny) has the same type of Bleed Nipple as the Brake Calipers do. First, you want to raise the Car securely. Then fill the Reservoir to the MAX line with fresh Brake Fluid (DOT4), fill and attach the Brake Bleeder. Now, you press the Clutch Pedal to the Floor and hold it in place with a Stick, Sno-Scraper (sorry Ronzi - couldn't resist) or anything which will hold the Pedal to the Floor, and then pump up the Power Bleeder to no more than 22 psi (I recommend 15-18 psi for an older Car as too much pressure can hurt the seals). Then go under the Car and attach a piece of plastic tubing to the Bleed Nipple on the Slave Cylinder which is at the upper left side of the Transmission and into a catch bottle. Be sure to immerse the Tube end in fluid in the catch bottle to prevent drawing any air into the system. Then you open the Bleeder Nipple and allow the Fluid to run out into the Bottle until it is clean and clear of any bubbles. Then close the Nipple, release the Pedal and de-pressurize the Bleeder and remove it, reinstall the Reservoir Cap - you're done. If you're Flushing/Bleeding the Brakes, there's no need to do anything except push the Pedal to the Floor and swing over to the Slave Cylinder Bleed Nipple as your last task. Will add maybe 5-10 min. to the Brake Bleed/Flush, you already have the Power Bleeder out and filled with Fluid, etc., so it's worth it. Happy Motoring!... Jim'99 |
Jim99, I have just purchased a power Bleeder because the clutch bleed without it is sooo difficult. You need the the arms and hands of an Orangatang!
I havent used it yet so I was surprised by your comment that it was necessary to hold the clutch peddle to the floor. Why is this? Tony W Quote:
Because the Clutch Master Cylinder does not have it's own reservoir, it needs to have the pedal depressed in order to draw from the one shared with the Brakes. Also, putting pressure behind the Master when connecting the Power Bleeder will cause the Clutch pedal to be moved by this pressure possibly damaging the Clutch Master. Here is a Quote straight from the Dealer Service Manual :
