Old 02-09-2014, 08:17 AM   #1
97red986's Avatar
Spark Plug Tubes
Thanks guys, what do you think about applying some heat?
97red986 is offline   Reply With Quote
Old 02-09-2014, 09:20 AM   #2
KevinH1990's Avatar
I had to try several times with the transom plug before I could make it work. It's been a while, but I remember trimming the outer "lip" of rubber on the plug so that it would fit further into the tube. I may also have used a pair of vice grips to prevent the plug from turning while I tightened it.
It appears that you can also remove the tupes with a pair of expanding pliers like these: ExpandingPliers.com - Pliers that expand and grab on the inside.
I think the problem with the pliers is that you can crack the tube and have pieces fall down where you cannot remove them.
Good luck.
Old 02-09-2014, 09:28 AM   #3
Actually, these would work better:
But put some soft rubber of vinyl hose over the serrated ends to keep from cracking the tubes.
Old 02-09-2014, 09:33 AM   #4
Jager's Avatar
Where did you get those? Supplier/part number?
Jäger
300K Mile Club
Old 02-09-2014, 09:49 AM   #5
Jager's Avatar
I found them... They are battery terminal spreaders. I have not seen them before, found them here:
Battery Terminal Spreader Pliers
Jäger
300K Mile Club
Old 02-09-2014, 09:55 AM   #6
97red986's Avatar
Thanks guys. What do you think about applying some heat to the area?
Old 02-09-2014, 10:01 AM   #7
Jager's Avatar
I bet those seals are stiff in that cold temperature... I'm sure a little warmth would help.
Jäger
300K Mile Club
Old 02-09-2014, 12:42 PM   #8
I used the 1" rubber arbor from my sanding drum set. Gripped much better than the transom plug.
'99 black 986
Old 02-09-2014, 01:28 PM   #9
The factory manual says to remove the tubes with the motor at operating temp, so yes, its easier to get them out when its hot. If you use the transom plug, clean the plug and the inside of the tube with brake cleaner.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 02-09-2014, 04:57 PM   #10
97red986's Avatar
Thanks everyone. So, the tube now has a minor crack and given the need to have the engine at operating temp, is it safe to run the engine with this crack. Btw, i have ordered the porsche tool to remove these tubes, these are a real pia.
