Old 02-10-2006, 07:38 AM   #1
Shift Points
Being that the only things I've shifted in a while are a Harley & a 20 year old Jeep I was just wondering where (in the RPM range) are Boxster drivers driving.
I'm not talking about banging it up the redline I'm talking about for comfortable highway driving.
PS: It will be an un modded 2003 S.
Jack-Jack is offline   Reply With Quote
Old 02-10-2006, 07:45 AM   #2
bmussatti
Posts: n/a
Your power peak is at about 4,500 RPM.
Old 02-10-2006, 10:26 AM   #3
Shift Points are largely a matter of circumstance - different for the conditions you're in. For normal cruising, shifting at about 2500-3000 is a good place to start...
Happy Motoring!... Jim'99
Old 02-10-2006, 10:47 AM   #4
2500-3000 is really too low unless you just started your car and temp is not over 180 yet.
When engine is fully warmed up, I always shift at 4000 rpm. The needle is right in the middle, so it's an easy benchmark. This is for "cruising" style shifting. For more spirited driving (my normal driving style), I shift at 4500 rpm to 5000 rpm. I shift above 5000 rpm when I need to merge into freeway and for really spirited driving.
yellowbox is offline   Reply With Quote
Old 02-10-2006, 10:57 AM   #5
Perfectlap's Avatar
I short shift more often then not. In the long run my engine will thank me.
Old 02-10-2006, 01:25 PM   #6
"2500-3000 is really too low unless you just started your car and temp is not over 180 yet.
When engine is fully warmed up, I always shift at 4000 rpm. The needle is right in the middle, so it's an easy benchmark. This is for "cruising" style shifting. For more spirited driving (my normal driving style), I shift at 4500 rpm to 5000 rpm. I shift above 5000 rpm when I need to merge into freeway and for really spirited driving."
Couldn't agree with you more Yellowbox. Surprisingly enough I've found shifting in the geriatric range (2000-3000) yields horrendous mileage as well.
06 987S- Sold
05 987 5-speed - Sold
06 MB SLK350- Lease escapee
SD987 is offline   Reply With Quote
