Old 01-22-2014, 10:33 AM   #1
weird slippage when turning
when i am backing our of a parking space or making a u turn, sometimes it feels like the front wheels are gyrating a bit form side to side... anyone have this?
dbansal is offline   Reply With Quote
Old 01-22-2014, 11:55 AM   #2
2004 2.7 Tip Lapis Blue
I have similar experience when turning on full lock, it's more noticeable at slow speed. Have jacked up, removed wheels and can't find any obvious problems. I have service due soon and will ask garage to investigate.
MadDad is offline   Reply With Quote
Old 01-23-2014, 09:04 AM   #3
Don't go hard or fast on full lock, very bad for the suspension and steering components.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 01-23-2014, 03:23 PM   #4
woodsman's Avatar
Sounds like a slipped belt but that seems unlikely. In a tight U-turn, the wheels are actually running on different trajectories and can cause some scrubbing but backing straight out you shouldn't feel anything. It could be a worn bushing on the trailing arm- maybe....Some tires flat spot after being parked and I wonder if that's what you're feeling when reversing? These cars have a lot of caster ( compared to what I've owned) and this puts things in an awkward position when reversing as can running a different offset from stock. I'd get an alignment at the best shop in town or at least remove both front wheels and stress the bushings this way and that.
Old 01-23-2014, 03:32 PM   #5
I get the effect when backing out if i roll over a rock that isn't centered on the tire. I attribute this to the ball baring effect from the rock and the wideness of the tires. They are wide enough that you get a little of the same effect welded/locked differentials give when turning.
Polaris is offline   Reply With Quote
Old 01-24-2014, 03:19 AM   #6
It sounds like the perfectly normal scrub you get with the steering near full lock, due to ackerman/castor jacking effects.
