Old 01-20-2014, 05:31 PM   #1
Alignment - caster
Is the 986's front axle adjustable for caster?
If so, are there knock-on effects? For instance, when you tweak the camber or toe, you get a knock-on effect on the other.
Thanks.
Old 01-21-2014, 02:02 PM   #2
woodsman's Avatar
I'm not aware of any provision for that other than opening up the holes for the top mount. The trailing arm at the bottom is fixed although I suppose those holes could be slotted as well...???
Old 01-21-2014, 02:55 PM   #3
OK, thanks. Didn't think so but wasn't sure.
Old 01-21-2014, 05:17 PM   #4
LAP1DOUG's Avatar
If you go with the RSS adjustable control arms, you can adjust caster as well as camber. Another option is to modify the existing control arms with new eccentric "pucks". I believe you can buy these from Tarett or RSS, and perhaps Elephant.
Kippis
986S
991S
Van Diemen RF97
