Old 01-17-2014, 12:17 PM   #1
CrashTest's Avatar
fuel pump diagnosis: stalling when warm
I'm having some weird issues with my 98 2.5 and think it might be the fuel pump. Before I drop a few hundred and get all stinky swapping the pump - is there any way to test the pump?
I was driving today - normal commuting and had no issues. Parked, returned, drove, everything fine. Then later in the day I hit some nice back roads, high RPM, high load stuff. When I pulled up to a stop sign the idle began bouncing up and down, almost stalling. Not sputtering or running rough, just up and down. At the next stop sign, the idle would dip and it would stall. It would immediately restart with the key, and if I feathered the throttle it would be fine. If I put it in neutral and left the throttle alone it died.
I read some accounts of bad pumps causing stalling when hot. It's odd that at high RPM high throttle opening, even in bend, I had no hesitation or stumbling but at rest, idle it would die. If the pump is going, wouldn't it have trouble with high-demand situations?
I pulled the relay and popped the cover off. No broken connections apparent, looks fine. The car sat maybe 10min and is behaving better. Idle a little wavy after throttle blips in neutral but no stalling.
Ideas?
CrashTest is offline   Reply With Quote
Old 01-17-2014, 12:37 PM   #2
98 Arctic silver 986
tommy583's Avatar
I had the same problem last summer. I cleaned the throttle body and the idle control valve. Ran great after that. Cost was one afternoon and a can of carb cleaner.
Old 01-17-2014, 02:37 PM   #3
woodsman's Avatar
when mine went it displayed a UNwillingness to rev high and was down on power. It also stumbled when at low revs. The next day it wouldn't start. I wonder if you've got a bad tank of fuel? Checking the fuel pressure is easy if you've got a $50 pressure tester (schrader valve- same as most cars).
Old 01-17-2014, 03:05 PM   #4
heliguy's Avatar
Originally Posted by woodsman View Post
when mine went it displayed a UNwillingness to rev high and was down on power. It also stumbled when at low revs. The next day it wouldn't start. Checking the fuel pressure is easy if you've got a $50 pressure tester (schrader valve- same as most cars).
Same symptoms when mine went.
Old 01-17-2014, 08:42 PM   #5
This is a good place to start and most likely needs to be done anyway. Doesn't sound like fuel pump.
Old 01-18-2014, 08:03 AM   #6
CrashTest's Avatar
Thanks all - will clean the TB and ICV today and see what happens.
Old 01-18-2014, 08:25 AM   #7
Could also be a vacuum leak. If you have a scanner, check the MAF and fuel trim values. If the Maf value is lowand the fuel trims are positive and high, then its likely a vacuum leak.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 01-18-2014, 12:14 PM   #8
CrashTest's Avatar
Took the ICV off to clean it - two things. Clearly the throttle body has never been cleaned. And the plastic body of the idle control valve is cracked. Going to replace the valve and gasket and see what happens next.
Hey san rensho - happen to have a 3Rensho?
Here's my restored 86:
Old 01-18-2014, 12:25 PM   #9
CrashTest's Avatar
edit: $270 for a replacement - silly.
Turns out the door, or valve, inside was stuck. It's freed up now - going to soak it and clean it a little more before shelling out $300 for a new part. Yikes.
Old 01-18-2014, 03:23 PM   #10
woodsman's Avatar
thanks for the update and may I say- I love that bike, including the colour!
Old 01-18-2014, 04:02 PM   #11
Yes I do! I got one of the first to come from Japan, but its a restoration project at this point. I need to find an old campy group to bring it back to its former glory.
Yours looks great. Nice conversion. SS or fixed.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 01-18-2014, 04:47 PM   #12
tommy583's Avatar
I feel like i actually helped . I hope it works out for you. I read on the forum somewhere that the ICV is also a VW or Audi part that looks exactly the same for much cheaper.
