Old 01-14-2014, 12:03 PM   #1
Registered Boxster abuser
healthservices's Avatar
Angry Automatic Trans cooler
Anyone know how the valve on the automatic transmission cooler works on our cars? Is the default open/closed ???
and when does it changed?
Old 01-14-2014, 01:56 PM   #2
Depending upon transmission and engine coolant temps, the Tip controller opens the coolant valve, so it is closed at low temps, but open at higher temps. The solenoid is activated when the trans oil reaches 185F, or the engine reaches 194F. The solenoid closes when the trans falls below 167F or the engine temp below 176F.
Old 01-14-2014, 04:30 PM   #3
Ill have to take a peak above to see if it is routed correctly to the solenoid
Old 01-14-2014, 04:40 PM   #4
Too bad I just put the hard top on!
