Old 01-11-2014, 06:32 PM   #1
cleaned my radiators
I finally bit the bullet and cleaned the radiators. Glad I did it. Dead bird on the front side and lots of trash built up in between.
Old 01-11-2014, 06:44 PM   #2
Rennzenn
j.fro's Avatar
Dead bird, wow! Best I ever got was a mummified frog.
Old 01-11-2014, 08:57 PM   #3
Road kill counts. Ten points for you.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 01-11-2014, 10:43 PM   #4
Tucker2's Avatar
Man....it's gross, right? Yeeesh.
Current: 981 Cayman
Former: '02 BS and '08 C
Tucker2 is offline   Reply With Quote
Old 01-12-2014, 02:28 PM   #5
Yep. The radiators smelled like dead animal. for sure
Old 01-12-2014, 07:06 PM   #6
linderpat's Avatar
did you pull the front bumper cover? Was it a hard job? Doesn't look to complicated in the write ups, and I will do this job soon.
Ed
Pittsburgh, PA
78 5 spd 928 Blumaxx (in Hemmings S & E issue #100)
85 928S garnet red stock daily driver
06 Mustang GT Legend Lime and modified to go even faster
linderpat is offline   Reply With Quote
Old 01-12-2014, 07:16 PM   #7
There Is No Substitute.
rick3000's Avatar
You have to remove the front bumper. It's not hard, but it does take a few hours. I did this when I added LED DRL's and an air horn. Never found anything as interesting as a bird though!
Old 01-12-2014, 08:11 PM   #8
I took my time. Probably took 2 hours for the entire job. Took about 30 minutes to remove the bumper. Hardest part was the behind the fender liner. I watch a 5 minute video on youtube. that REALLY helped.
Old 01-13-2014, 10:47 AM   #9
linderpat's Avatar
Originally Posted by jdlmodelt View Post
...I watch a 5 minute video on youtube. that REALLY helped.
linky?....
Ed
Pittsburgh, PA
Old 01-13-2014, 05:39 PM   #10
linky?....
Porsche 996 986 bumper removal - YouTube
there's the link!
Old 01-18-2014, 02:03 PM   #11
Radiator cleaning
Another alternative to removing the front bumper assembly is to buy some dishwasher hose or other flexible hose. Get about three feet and make sure it is sufficiently sturdy that a vacuum cleaner won't collapse it. I attached the dishwasher hose to a shop vac and push through the air slats on the front bumper. You may want to put a little painters tape on the bumper so it won't scratch the paint. You can then maneuver the hose around and get a lot of accumulated leaves, etc from the radiator. This is not as thorough as removing the bumper, but it is quick and easy.
Blackcloud is offline   Reply With Quote
Old 01-18-2014, 09:43 PM   #12
doragman's Avatar
Thanks for reposting -- I noticed some needle movement on hot days last summer -- on my agenda for Feb
'99 986 Baton Rouge, LA
doragman is offline   Reply With Quote
Old 09-13-2014, 12:17 PM   #13
gomarlins3's Avatar
Thank you.
gomarlins3 is offline   Reply With Quote
Old 09-13-2014, 03:30 PM   #14
rp17's Avatar
Good tip but if you or a shop haven't removed the bumper in a while, go through the whole procedure and separate the radiators. You will be amazed whats in there.
Old 09-13-2014, 03:42 PM   #15
Did mine last weeknd.
bobbeck is offline   Reply With Quote
Old 09-13-2014, 04:49 PM   #16
Spinnaker's Avatar
I don't know if it is just me, or if others have this happen to them.
After cleaning out the radiators, do you cringe when you see leaves swirling on the road in front of you? You just know that they are going to get sucked into the grill and clog up the radiators again.
Old 09-13-2014, 08:49 PM   #17
gomarlins3's Avatar
That's why I did it today before I put on my new grill guards.
Before:
After:
Old 09-14-2014, 02:31 PM   #18
gomarlins3's Avatar
Frustration= Putting the very last bolt in as you reinstall your front bumper back on with the new grill guards and you realize you forgot to put the temp sensor back through the holder.
AAGGGHHHHHH!!!
Old 09-14-2014, 05:13 PM   #19
Coaster's Avatar
What grill guards did you put in, got a pic or link?
Coaster is online now   Reply With Quote
Old 09-15-2014, 04:44 AM   #20
gomarlins3's Avatar
Porsche Boxster mesh grill radiator guards
