Old 12-07-2007, 07:13 PM   #1
blkboxster
Guest
Posts: n/a
IM Nervous
Ok, so my new rims are 18X10 in the rear with 265 35 18, so i got bored and decided just to put the rim on the car, its a 1999. so i put the rim on but i didn't lower it still on the jack. and it looks like there very small space between the rim and i believe the shock absorber with out the tire on. so no im nervous will these rims with 265 35 18 fit on the rear of my car?? or was it because my car was not lowered still on the jack??? sorry guys for so many questions.
thanks
Old 12-07-2007, 07:21 PM   #2
EE3racing
Guest
Posts: n/a
OK even though you puked on my wheels and dissed my ride..I have an idea for you. To safely check whether the geometry is differing because of being jacked up or whether it's an optical illusion, you need to put your factory scissors jack in place. Then you can control lowering or raising the car smoothly and infinately. This way you can check your clearances without fear of damaging the new wheels, good luck.
Old 12-07-2007, 07:23 PM   #3
blkboxster
Guest
Posts: n/a
Ok, nickcats has the same tires 8" turbo twists ( 993 Turbo Look/Technology )
Nexen N3000 tires on the rear ( 265/35RR18 ) and Fulda Carat Extremo tires on the front ( 225/40ZR18 )
Came with the car
and it fits on his 99 fine. so am i fine???
Old 12-07-2007, 07:26 PM   #4
It all comes down to wheel offset. The 265-35-18 was the factory size rear tire when Boxsters were ordered with 18" rims (admittedly, on 9" wide for boxsters), so I wouldn't worry about the tire.. I would worry about the rim.
The suggestion above (xusmnj....)my post is a great idea. Be sure to put a towel/cloth on your jack so you don't scratch your rim either.
My guess is that, with the car merely raised, the clerance is tighter than when the car is lowered, due to the movement of the rear suspension.
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
racer_d is offline   Reply With Quote
Old 12-07-2007, 07:29 PM   #5
blkboxster
Guest
Posts: n/a
my off set for the rear is, 40MM REAR, am i fine ???
Old 12-07-2007, 07:38 PM   #6
Send a message via AIM to blinkwatt
You got the wheels off of eBay correct? If I remember correctly the link I saw had big offsets,meaning you'd need spacers. What are the offset specs?
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 12-07-2007, 07:52 PM   #7
blkboxster
Guest
Posts: n/a
REAR ARE 40MM REAR
Old 12-07-2007, 08:35 PM   #8
My guess is you'll need 5mm spacers. My rears are 18 X 10 with ET 47...I still rubbed the parking brake cable, but cleared everything else.
Old 12-08-2007, 04:17 AM   #9
blkboxster
Guest
Posts: n/a
Great!! i couldnt even sleep last night worring that they wont fit, thanks guys
Old 12-08-2007, 10:12 AM   #10
blkboxster
Guest
Posts: n/a
Got them on with no problem and they look amazing i will post pic when ever i can.
