Old 12-03-2013, 06:58 PM   #1
evo-r's Avatar
Question HELP... Wet upper frunk??
Ever since I bought the car this past March I've noticed whenever it rained hard, my frunk will be a little wet, and I tried to pin point the leak with no luck. The last time it rained was 6 days ago with almost 2" of rain in one day. Today I open the frunk just to see if there is any water and this is what I discovered (I removed the battery cover before taking the pictures).
The car is parked outdoor with an outdoor custom fit car cover (Covercraft Evolution), but water can still go through. For some reason the water is going passed the upper frunk seal. I did clean out the drains by the battery when I first bought the car thinking that would solve this issue but obviously not. The frunk seal looks good with no rips. The water condensates/splashes are only in the upper center section near the radio amp. Anyone had experienced this or has any insight on what could cause this leak? Thanks!
His: 2003 Boxster & 2008 MDX
Hers: 2011 Golf TDI
evo-r is offline   Reply With Quote
