Old 11-25-2013, 11:55 AM   #1
Waxy white residue when using a car cover??
I've always had this happen to me on whatever car I've owned.
I buy a decent car cover, doesn't matter the manufacturer and after a few days I notice some waxy/oily white buildup all over the car/windshield. I wondering if anyone else has encountered this problem? Has anyone found a fix for this. You spend hours detailing the car and in about 3-4 days it's pretty much ruined with whatever is happening under the car cover.
Thanks guys!
Trax is offline   Reply With Quote
Old 11-25-2013, 11:56 AM   #2
jakesbox
trimer's Avatar
Thanks guys!
I have not...always used california car covers. Not sure if the maker has anything to do with it, but maybe put a towel over the windshield prior to putting on cover?
Old 11-25-2013, 12:33 PM   #3
This is moisture coming out.
Old 11-25-2013, 01:34 PM   #4
I'm sure it is moisture as well. I just don't know if it's mixing with the wax or not. My car sits under a car port so it's not in a garage at the moment. I'm just lost on what I can do to stop the car getting this white crap all over it.
Old 11-25-2013, 01:42 PM   #5
Wax or sealant? Do you cover right away or let it cure?
Old 11-25-2013, 02:06 PM   #6
Ahhh! I do tend to cover it after i'm done pretty fast. Wonder if that is the problem. Someone said to get custom weave from California Car Cover. But oh my it's $$$ but it's supposed to not leave a residue (911 forums). Wonder if the real Porsche covers do this?
Old 11-25-2013, 02:11 PM   #7
Originally Posted by TOGWT:10392127
Paint will sometimes show ‘hazing” after removing a car cover that has not allowed hydration (transpiration and evaporation of moisture). The temporary hazing, which can appear as a slight dull discoloration, stain, or raised surface in the paint is caused by the paint finish absorbing moisture
Correction- In most cases, by applying Isopropyl alcohol and exposure to heat (sunlight) allows the moisture to evaporate within a few hours. For colder climates, moisture evaporation recovery can be accelerated by placing the vehicle indoors and using a portable infrared heat lamp (or professional-type heat gun). Allow the affected area to outgas by not using a wax or sealer on the affected are for a few days
In extreme cases if a waterproof cover i.e. a tarp is used to cover a vehicle it may cause delamination. A polyurethane paint (high solid / low solvent) clear coat can absorb moisture; as water molecules are smaller than a cross-linked clear coats molecule.
Moisture (condensation) can permeate and break down the chemical bonds between the clear coat and the basecoat; this sometimes produces small bubbles in the paint surface. This will also cause delamination between the layers since once the chemical bond is destroyed; only the weaker mechanical bond remains.
Old 11-25-2013, 02:12 PM   #8
Autopia Detailing Wiki - Autopia
Old 11-25-2013, 04:14 PM   #9
jcb986's Avatar
California Pop Top. Covers the top, front to back and reduces sun light. Made from Tyvek.
Old Hippie Young Heart
Old 11-25-2013, 04:30 PM   #10
Joe B's Avatar
+1 for California Car Covers. I've used mine nearly every day for a year now with no residue.
Old 11-25-2013, 04:50 PM   #11
Joe which cover did you buy? There are a bunch. I'm looking for an outdoor one.
