Old 11-24-2013, 11:09 AM   #1
haz
haz's Avatar
Rough idle when warm, anyone knows why?
Only when warm, not when cold, its chasing when idling. Anyone? (Replaced MAF 3 weeks ago, and this problem just arrived..)
Jager på tomgang - YouTube
haz is offline   Reply With Quote
Old 11-24-2013, 11:24 AM   #2
jcb986's Avatar
I am thinking, vacuum leak. Did you check to see if the AOS is good. Also, was this an issue before replacing the MAF.
Old Hippie Young Heart
Old 11-24-2013, 11:32 AM   #3
haz
haz's Avatar
I'm considering vacuum leak also. How do I check the AOS? No, this problem arrived friday and only when warm.
Old 11-24-2013, 12:17 PM   #4
jcb986's Avatar
When the engine has warmed up, try removing the oil filler cap. If it does not unscrew and remove easily then the AOS is not working as should. Then replace it. Are there any codes being thrown?
I usually work backwards...put the MAF back on and see if it has the same problem. If not then put the new back on and make sure it is seated correctly...you also could have a bad part.
Old 11-24-2013, 09:46 PM   #5
Guvs's Avatar
Just a thought, did you disconnect the battery before you put the new maf on ? this will allow the on board computer to learn all the settings from new, it may be working on the old maf settings.
Guvs.
Guvs is offline   Reply With Quote
Old 11-24-2013, 11:14 PM   #6
haz
haz's Avatar
Guvs.
No, but the new has MAF worked fine. It did not throw any codes either after new MAF + the car has the new software (this newest MAF requires it).
I will connect the casr and check for codes on saturday, as I was planning to visit my friends Porsche-garage anyways. I will also check your "unscrew the oilcap"-trick after work today also
Thanks so far guys!
Old 11-25-2013, 11:15 AM   #7
haz
haz's Avatar
Someone tipped me it could be the "idling regulator" (if dat is de engrish wørd for eet)
Old 11-25-2013, 11:57 AM   #8
Spinnaker's Avatar
Try cleaning the throttle body.
Old 11-25-2013, 12:22 PM   #9
haz
haz's Avatar
Thanks! Added to my check list for this saturday
Will also check the Idle speed control valve.
