Old 10-20-2013, 02:59 PM   #1
TRPLBLK04's Avatar
dipstick tube
Hello.....new to forum. seems that the top of dipstick tube has slipped down below plastic outlet hole. How to pull back up. looks to have tabs that hold in place? Many thanks in advance.
TRPLBLK04 is offline   Reply With Quote
Old 10-20-2013, 03:20 PM   #2
kjc2050's Avatar
This might be of help:
Broken dip stick tube
Old 10-20-2013, 03:30 PM   #3
TRPLBLK04's Avatar
Thank you kjc2050, but it does not seem to be broken, just pushed down in trunk, where top of stick pushes in. do you know if i remove hex bolt on bracket i can get it there to push back up, stap back in?
Old 10-20-2013, 03:33 PM   #4
TRPLBLK04's Avatar
p.s.......and or side of carpet, surounding the tank and fill spots?
Old 10-20-2013, 03:44 PM   #5
kjc2050's Avatar
I don't know. Try searching the forum for "dipstick tube repair" or "dipstick tube replacement" or something along those lines. ...or perhaps someone else can comment.
Old 10-20-2013, 03:58 PM   #6
TRPLBLK04's Avatar
10-4 thanks. Found access bu removing carpet. must have broken tabs or somthing cuz nothing to snap in when pushing up. Anyone with pic of top if dipstick tube? with dipstick removed?
Old 10-20-2013, 04:30 PM   #7
kjc2050's Avatar
These may be of help:
Oil fill tube Q - 986 Series (Boxster, Boxster S) - RennTech.org Forums
http://986forum.com/forums/general-discussions/15127-oil-filler-tube-install.html?postid=133458#post133458
Old 10-20-2013, 05:11 PM   #8
TRPLBLK04's Avatar
kjc........Thats oil (fill) tube. I'm talking dipstick tube. or more like a small hollow mesh type cable that the dipstick inserts in.
Old 10-20-2013, 05:24 PM   #9
kjc2050's Avatar
oops, sorry. Google + search.
Old 08-31-2018, 07:21 PM   #10
Did you ever find a solution. I have the same problem.
BlueStreak81657 is offline   Reply With Quote
