Old 10-01-2013, 11:26 AM   #1
CEL P0430 fix that worked for me
Over the course of about 4 or 5 months, I kept tripping a CEL P0430 about every 3 or 4 weeks, especially after taking it on a longer trip (over 100 miles). I'd clear the code and sure enough it would come back.
After looking at nearly every post about this code, I found one that suggested that you check the gas cap and check for cracks in the rubber O-ring. Yep, mine had about 10 - 12 cracks in it
I got a new one from Pelican Parts for $15.50 including the pop rivet. (There are threads about how to remove the old pop rivet and for installing the new one.)
1000+ miles later and I haven't tripped the P0430 code once. Sometimes the problem isn't a big one or an expensive one. If I trip this code again soon, I'll be looking to replace some O2 sensors. Until then...
2001 Boxster - savanna on black
1960 MGA
http://i8.photobucket.com/albums/a18...7/mgaside2.jpg
impboy is offline   Reply With Quote
Old 10-01-2013, 11:31 AM   #2
Topless's Avatar
Good call! A fresh gas cap is the #1 cure for P0430. If you get the code again, look to gas tank venting and evap system. It will never be tripped by faulty O2 sensors.
Old 10-01-2013, 12:35 PM   #3
Thanks for the info! I thought I read somewhere about the O2 sensors being an issue but I guess I was wrong.
:dance:
1960 MGA
Old 04-16-2014, 09:34 AM   #4
oc-boxster's Avatar
Digging up this old thread doing a search. My 02 keeps tripping the 0430 code as well. And I am having problems with fueling my car, the pump clicks off and I have to reseat the nozzle a lot to reseat it. Can the vent system now be faulty giving me the code?
oc-boxster is offline   Reply With Quote
Old 04-16-2014, 09:44 AM   #5
There is a post somewhere discussing the tank vent system creating problems with fueling and hot starts. I do not recall if it mentioned a CEL. A search for hot start issues might turn up the posts.
Old 04-16-2014, 02:18 PM   #6
I am my own mechanic....
Timco's Avatar
Don't know about the error code, but some CA gas pumps would click off instantly when I filled up because of their fume recovery sealing fill nozzles and the short fill tube and tight bends in the cars fill line. Took forever to get 1/2 tank even. Never happened since I drove it to UT.
'08 VW Touareg T-3 wife's car
Old 04-16-2014, 02:28 PM   #7
oc-boxster's Avatar
Thanks timco!
