09-27-2013, 01:49 PM
#21
Originally Posted by teleski
When was green coolant discontinued by Porsche?
My 2k box received a factory reman engine in 2005 by a Porsche dealer (and had the expansion tank replaced in 2008 with no mention of coolant flush).
I received the car with green coolant which the PPI noted as incorrect. Would a dealer in 2005 have used green?
The new coolant was fazed in around 2005. Porsche was careful to make sure the green and pink coolants are totally compatible (read mixable), so adding pink to a car with green in it would not cause an issue. However, as most dealers buy coolant in bulk (usually they store it in a large 250-500 gallon tank), it took a while for most of the dealership shop area's to work off their existing stocks.
It is possible to swap out the coolant tanks in these cars without totally draining the system, so they may have just toped it up with the green stuff.
09-27-2013, 01:52 PM
#22
Originally Posted by max_asdf
no, it hasnt been clearly answered. if you read my previous post from the dealership, the same dealership is telling me it is OK and IT IS NOT OK to use prestone.
they are also refusing coolant flushes..
It has been, however you are not seeing it. The parts guy is correct, you should not mix brands. The service writer is also correct, if somewhat vague in how he is phrasing it; he appears to be talking about the Porsche coolant by color (e.g.: Don't use the green, use the later pink).
And just as a reference point, in general, service writers are the last ones to ask technical questions; most end up on the service desk because they lack the skills to work in the shop. Parts guys, on the other hand, learn from experience what works and what to avoid.
And if the dealer does not want to do the change out, you are money ahead as doing it yourself is one of the easiest maintenance projects short of an oil change on these cars...........
09-27-2013, 03:03 PM
#23
I then followed up and tried to book a coolant flush appointment, and they refusued it, as the coolant is lifetime and they dont do or advise any flushes being done.
Lifetime? I put this out-of-warranty advice in the round filing bin. The same one I used to file "the IMS is a lifetime part, why do you think they made the 05-08 IMSB non-extractable? Life time part buddy, no need to worry".
Wayne Dempsey in "101 Projects for your Porsche Boxster" recommends changing the coolant every two years. I plan to do the coolant cap, brake fluid and coolant at the same time going forward.
09-27-2013, 04:17 PM
#24
Originally Posted by JFP in PA
Because we are a shop, I tend to take the "belt and suspenders" approach to this type of problem because we do not want to have a customer stranded somewhere as the result. I would dump and flush the system.
This way, you sleep better at night..............
Personally, I think Jeff's advice is spot on. I have enough trouble sleeping at night the way it is
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
09-27-2013, 08:05 PM
#25
Toyota used to say to their customer the same way that Porsche say about their coolant. For over a decade, Toyota was the only company that use the pink coolant that does not contain silicate, nitrate, or phosphorous. That has all changed when people just use over the counter coolant that does not contain those three chemicals w/o any effect.
Honda always recommend their ATF for their transmission, people quit using them because they believe it causes damage to their V6 trannies.
What I'm saying is, do your research and stop listening to car makers.
For porsche coolant, just get any coolant that does not contain silicate, nitrate, or phosphorous. Try Zerex for asian car that is pink color.
09-28-2013, 04:02 AM
#26
If you thoroughly and completely drain and flush out (multiple times) the system to remove any trace of the OEM coolant, you can use just about any aftermarket aluminum/alloy compatible coolant in these cars.
That said, if there is any trace of the OEM product in the system, and you happen to choose an aftermarket brand that is not compatible with the OEM coolant, well, good luck cleaning out what happens next.
Then add in the fact that the OEM product is very good both in protecting the alloy components and in how long it can live (properly installed, we have seen it go 7-8 years without problems and still test fine), it is readily available, and not all that expensive; and you have to ask yourself "Why bother looking for a substitute?"
09-28-2013, 05:21 AM
#27
Thanks for the advice. I will flush my coolant sometime soon.
Just sucks becuase one guy decided to put 2L of prestone into my 22Litres of oem coolant while he could of just put in water to avoid all this trouble.
09-28-2013, 06:04 AM
#28
Which is why you always need to be alert when someone else touches the car; a moment of diligence often saves hours of grief.
09-28-2013, 08:53 AM
#29
And only use a mechanic who is thoroughly familiar with Porsches.
DEPO Tail Lights
09-28-2013, 08:55 AM
#30
Just had my coolant flushed and filled - G11 which the Porsche indie tech said was correct for Porsche. It is blue!
I have always driven Audi's which uses G12 (pink).
2001 Boxster S SOLD
Seal Grey/ Graphite Grey -Design Package-Sport Design Package- PSM- Litronic Lights-Headlight Washers
XRL (GT3) 18" Wheels-Heated Seats-CD Center Console
09-30-2013, 05:06 AM
#31
What is a good flush procedure for the DIY guy without Vacuum filler?
Drain via Drain plug and radiator hoses, refill with Distilled water, burping via Bleeder valve, driving some small period of time? - Follow Bentley procedure basically
Repeat till only clear water is drained?
I initially didn't hesitate in buying Porsche coolant. I topped off maybe 1/4 - 1/3 pint many months back. The other day I topped of with about a 1/2 pint of Distilled water after getting new Cap. I looking in the tank I see green in the bottom. So Now I don't really know what is in there. Whether the previous owner switched to general coolant or not. Now I'm afraid to add my Porsche coolant. So it's time to flush and start with a known Porsche coolant
Seal Grey
09-30-2013, 05:34 AM
#32
A good flush procedure for the DIY guy without vacuum filler:
Step 1: buy a vacuum filler
Seriously, this tool is worth its weight in Porsche coolant. Makes the job dead easy.
'99 black 986
09-30-2013, 07:10 AM
#33
Mark_T you are right as I have several other cars(kids, wife) It would be useful for them as well. Need to get a Compressor.
I have thought about it and I'm thinking this would also be the time to do water pump and Low temp thermostat
Seal Grey
09-30-2013, 08:03 AM
#34
I would suggest getting a compressor big enough to run air tools. You will wonder how you ever got by without them.
'99 black 986
09-30-2013, 08:26 AM
#35
Especially if you're doing this at a regular interval instead of just having the same coolant in there for a really long time.
P.S.
I would get a label maker and stick it to the tank: "WARNING:PINK COOLANT ONLY!"
09-30-2013, 07:34 PM
#36
So what does happen when I use coolants I listed above?
09-30-2013, 07:39 PM
#37
Maybe it's good to explain why because many people like me dont ever use one.
10-01-2013, 02:31 AM
#38
If you mix the OEM coolant with an incompatible aftermarket brand, the most common problem is the formation of large quantities of gel, often looking like loose porridge in consistency. Besides leading to overheating issues, it is usually one Hell of mess to clean out of one of these cooling systems..........
10-01-2013, 02:33 AM
#39
With a vacuum filling system, it is a 5 min. process to refill the entire cooling system without any problems; no air pockets ever, no "burping", no running around with the surge tank vent open, no topping the system up. You fill it, and it is done.
