Old 09-25-2013, 09:11 PM   #1
Need some help with offset for 19" wheels
Hey, I'm looking to buy some wheels for my 02 boxster and was wondering if stock 19" off a 987 would fit without spacers. Here are the sizes 8/57 and 9.5/46. Thanks
juicepro is offline   Reply With Quote
Old 09-25-2013, 09:16 PM   #2
Trey T's Avatar
I have the 996 "twist" below in 18" with 23mm spacer for the rear. The front didn't need it.
Trey T is offline   Reply With Quote
Old 09-25-2013, 09:24 PM   #3
Johnny Danger's Avatar
The short answer is yes. Although the offset for the front wheels is quite high. I would recommend lowering the offset by at least 10 to 15 mm's for starters.
Old 09-26-2013, 05:58 AM   #4
Does that mean I need spacers for the front to make it flush? Where can a buy some spacers?
Old 09-26-2013, 06:36 AM   #5
Sorry if I'm stating the obvious, but installing spacers will also require longer lug bolts, which ramps up the cost considerably.
'99 black 986
Old 09-26-2013, 07:12 AM   #6
Trey T's Avatar
I got the kit from ebay for about $140 (pair). I don't know how precise it is but it drives smooth. I might have to put a dial indicator to the hub one day.
The spacer I got is secured with two screws to the spindle. Obviously, you have to take off the screws at the rotor.
