IMSB Seasonal Storage
04 S
Winter storage will soon be an issue for some of us. I am finishing an engine rebuild and a LN IMS Upgrade (triple row). I've read some arcticles on the IMSB and the most recent one by Pedro, again pointing out the fact that the IMSB is always partially lying in oil. The more time the bearing is lying in oil not moving or moves but at low rev's (garage queens) the greater the chance for future problems. With the sealed bearing lying in your dirty engine oil for extended periods, its only time then the oil seeps past the seal leading to the the future problems we all talk about and fear, IMSB failures. To the point - For those of us who lay their cars up every year for 5-6 months would it not be advisable to change the oil and filter before lay up but hold back 2 litres/quarts, thereby keeping our bearings free from lying in the oil? Or just drain off 2 litres before lay up to keep the sealed bearing free from the oil? Is 2 litres enough to get the oil level below the bearing? Off course after lay up top up the oil, bring her up to temperature and drive it like hell, keep the revs up! With the LN IMS Upgrade, is it a concern if my bearing is lying in engine oil for an extended period not moving? |
If the oil is clean I can't imagine how the IMSB can suffer additional deterioration by partially lying in it.
the bearing doesn't sit in the oil pan (where holding back oil would decrease the level). the oil pedro is talking about is oil that's found its way into the shaft and sits against the backside of the bearing.
If so, then I would change the oil close to storage time, drive it for a couple of hours, then store it. I realize there would still be some unclean oil, but there is also the fact that i don't want to drive it in salt the next 6 months. |
The only way oil gets into the IMS is thru both IMSB seals. Once in the IMS it tends to stay there until the IMSB is replaced. Removing the outer IMSB seal helps get fresh oil to the bearing. Changing oil before long term storage is the best thing to do.
So no significant amount of oil gets into the shaft from the other regular bearing?
IMS seals degrade when they get whetted with oil that contains acids and other combustion byproducts. The best strategy to slow deterioration, that is minimize it, is to keep the oil fresh and clean. Many people change oil just before storing their cars as part of this approach.
Seems to me that the acid theory should be easy to prove even on an engine that suffered IMS failure, simply by sending the parts for analysis by a testing lab.
If you are doing an LN Engineering IMSB upgrade, there is no seal to worry about any longer.
04 S
OK I have to go drive my car again, pick up a magnetic drain plug, but before I go. Its good to know the best preventive maintenance for our IMSB is, change oil frequently and change oil before putting away for long term storage. On the matter of oil level does any one actually know where the oil level is relative to the IMSB? Pelicans instructions, for IMSB replacement, tell us to have a drain pan ready when removing the chain tensioner plugs thats after having drained the oil and removed the filter. These chain tensioners are pretty close to being in the same plane as the bottom of the IMSB. A rebuilt engine takes almost 11 quarts of oil. Normal oil change and filter is almost 9 quarts of oil, this is a healthy quantity of oil. Where is the oil level? |
JFP, If the oil level is above the base of the sealed bearing then wouldn't it minimize bearing failure risk to lower the oil level below the bearing for seasonal storage?
Perfectlap at the time I didn't have the choice.
After my IMSB failed and I was faced with a rebuild it became questionable if my IMS was even re-useable. (finding a second hand IMS wasn't easy at the time, I didn't want porsche's new IMS) I sent it to LN Engineering and fortunately they were able to work with it and upgrade it to the triple row and pin the sprockets to the shaft. At the end of the day I still have bearings, not sealed but still bearings, in an oil environment, engine oil. I'm not an engineer or mechanic but I don't like the idea of a sealed bearing in a liquid. I'm pretty sure its the only one in the whole engine. Most other things around this bearing are journal bearings, similar to The IMS Solution. Its just smooth steel and oil, if the oil stops flowing .... well the rest of the engine is also toasted, not because of the IMS Solution. I was a few months to early for the IMS Solution and many miles away from an authorized installer. |
Interesting.
Does the triple row shaft approach incorporate DOF? Otherwise how are its bearings serviced? |
The IMS Solution was developed for my engine program, and was invented right here by Charles Navarro and I. See the "Tech Forum" in Excellence Magazine in November of 2013 for a 3,000 word feature on the IMS Solution. |
Below is the IMS I sent to LN Engineering with a view of the beat up bearing race.
http://986forum.com/forums/uploads01...1380374827.jpg http://986forum.com/forums/uploads01...1380374863.jpg Below is the rebuilt IMS and a view of the new IMSB. This is how I received it back from LN Engineering (well the flange was actually attached to its stud but that hides the bearing for a pic.). If you could enlarge the photo you can actually see the ball bearings and see they are not sealed. http://986forum.com/forums/uploads01...1380375177.jpg http://986forum.com/forums/uploads01...1380375218.jpg |
I bought an old style IMS with bearing on ebay - very hard to find - to rebuild my 3.2 with a failed IMS. After reading Pedros thoughts on IMS bearing failure I convinced myself to remove the bearing and check for oil in the IMS, and boy howdy did I find it! Ther was about half a cup of rancid engine oil in the IMS. It was so bad there were chunks of what appeared to be baked oil floating around in there. It even smelled bad. The bearing seals looked good, and the bearing feels ok. No evidence of corrosion on the bearing inner surface or interior of the IMS. Still, a replacement beaing is in order. I see two paths for oil intrusionand subsequent acidification into the IMS. 1) through the non metalic seals on the OEM bearing, 2) around the bearing to IMS interface. I wonder if falures are determined by which path the oil takes?
| All times are GMT -8. The time now is 01:24 PM. |
