Old 09-15-2013, 01:26 PM   #1
Need help diagnosing this bizzare radio failure
The CDR220 on my '99 cuts out, as in loses all power, at random. Sometimes it will cut out for just a few seconds before turning back on, sometimes it won't work for several days. It seems like electrical loads sometimes influence the unit losing power, such as turning the AC on, using a window switch, etc. Another time I noticed that the radio would work just fine with the engine idling, but lose power once you gave the car any revs! What's interesting is it works 100% of the time when the key is turned to the accessory position, but once you start the motor, the intermittent failures start. Car has no other electrical glitches.
Ignition switch? Bad head unit? Fuse? What's the prognosis?
black_falcon is offline   Reply With Quote
Old 09-15-2013, 01:42 PM   #2
Failing Ignition Switch would be my guess, too. That can cause all kinds of electrical gremlins. Then, look at a poor ground.
Old 09-15-2013, 02:07 PM   #3
I am my own mechanic....
Timco's Avatar
Mine will not play a CD in winter until the car warms up substantially. Swapping next week.
'08 VW Touareg T-3 wife's car
Old 09-15-2013, 02:41 PM   #4
An original CD or a "burnt" copy??
Old 09-15-2013, 07:18 PM   #5
Timco's Avatar
New ones or CDR. It is sluggish then re-starts. Looses presets. That's just when it's below freezing. I turn it off then back on when it warms up.
Old 09-15-2013, 06:53 PM   #6
Going through same thing right now. Planning on replacing ignition switch soon. I've done it before and it solves lots of weird stuff!
