Old 08-18-2013, 05:05 AM   #1
Victor wheels on a Boxster
I have recently run into an issue with a set of Victor Innsbruck wheels. They are the recommended size to run 18 x 10 with a 50 MM offset. When test fitting them they hit the shock tower on the back. The spacing is minimal but will still need a spacer to make them work. My question to the board is has anyone else been over this bridge? The Advice from TSW/ Victor was, "for me to change my style of wheel". I am looking for friendly information before flaming TSW and Victor for crappy advertising and misleading information.
Perrytbiii is offline   Reply With Quote
Old 08-18-2013, 05:29 AM   #2
madmods is offline   Reply With Quote
Old 08-18-2013, 05:42 AM   #3
welles's Avatar
Offset for factory 10" rear wheels is 65 mm.
welles is offline   Reply With Quote
Old 08-18-2013, 05:51 AM   #4
Old 08-18-2013, 06:29 AM   #5
jacabean's Avatar
if you really like the wheels just add the spacer , no big deal there . i run 15mm spacers on my rears . I would even like to move up to 20mm to make the wheels sit more flush.
Old 08-18-2013, 07:10 AM   #6
LAP1DOUG's Avatar
I believe that is a 996 wheel fitment, which should work on a 986 Boxster if you use a spacer of about 18 mm.
Kippis
986S
991S
Van Diemen RF97
Old 08-18-2013, 07:29 AM   #7
Old 08-18-2013, 09:16 AM   #8
BruceH's Avatar
Originally Posted by madmods View Post
That would certainly make a bit more sense
I have 10" wheels from a 996 with an offset of 65. I used a 20mm spacer which then clears the shock tower.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 08-18-2013, 09:20 AM   #9
Old 08-18-2013, 09:39 AM   #10
BruceH's Avatar
Yes that sounds about right. I would have imagined a 25mm spacer but surely the 20mm should sufficient enough.
In the OP's case, I'm sure he only needs a 7mm spacer and hes done
Yep, 7mm would be perfect
DEPO Tail Lights
Old 08-18-2013, 09:54 AM   #11
Old 08-18-2013, 01:56 PM   #12
Johnny Danger's Avatar
Just lower the offset to +45, or +40 if you want a more aggressive look, and you'll be fine.
