Old 01-15-2006, 02:03 PM   #1
Locking Gas Flap?
Is the body flap that opens to the gas tank supposed to be locked when the doors are locked. Mine does not.....
docdyh
docdyh is offline   Reply With Quote
Old 01-15-2006, 02:21 PM   #2
bmussatti
Guest
Posts: n/a
On the 987- yes.
I don't know about the 986.
The 987 has a small actuator that locks the flap.
Old 01-15-2006, 02:47 PM   #3
QporscheQ's Avatar
yes on 986 too.
Q
QporscheQ is offline   Reply With Quote
Old 01-15-2006, 07:48 PM   #4
creseida
Guest
Posts: n/a
Mine does.
Old 01-16-2006, 06:38 AM   #5
Mine doesn't. It should do tho, but the mechanism is sort of busted.
rich is offline   Reply With Quote
Old 01-16-2006, 03:30 PM   #6
ohioboxster's Avatar
I never knew mine locked until I read this thread, it works.
2002 TT
ohioboxster is offline   Reply With Quote
Old 01-16-2006, 04:23 PM   #7
so why doesn't mine work..does it need some sort of actuator?
docdyh
Old 01-16-2006, 06:21 PM   #8
When you lock the car you should see a little peg poke out. You can open the gas flap and then lock/unlock the car and watch for it.
My flap lock recently started making a really loud click when I lock the door, but I can't figure out what changed in the mechanism.
xavier405 is offline   Reply With Quote
Old 01-18-2006, 11:45 PM   #9
Hi,
One thought occurs to me. There is an Emergency Release cable for the Fuel Flap located in the Passenger Side Door Jamb.
Inspect this to insure that it is not kinked or hanging up in any way preventing the Latch from Locking. You might also try pulling it several times to try and loosen a stuck mechanism. Hope this helps...
Happy Motoring!... Jim'99
Old 01-19-2006, 10:47 AM   #10
Maybe a little lubrication of the lock and cable might help. Since it is exposed to weather,
mike
2002 S. Black on Grey. Fun Fun Fun
chily3 is offline   Reply With Quote
Old 08-24-2011, 07:53 AM   #11
Fuel flap release broken
Flap was jammed I tried to use release by pulling ring and complete plastic pull thread came out. Has a smaller ring on working end which must attach to something. Can this easily be fixed?
Nigel Willis is offline   Reply With Quote
Old 08-24-2011, 07:47 PM   #12
DenverSteve's Avatar
Great
This is why forum's like this are so great. I too never knew about the locking cover. I checked mine and the mechanism was working but the cover did not lock because the retaining clip had fallen off and down below the cap in the tray. Replaced it where it was supposed to be and it locks again. Great question and information.
Denver Steve
Carrera, Cabriolet, 6-Speed, Black/Tan
DenverSteve is offline   Reply With Quote
