-   -   CDR220 Question (http://986forum.com/forums/boxster-general-discussions/47781-cdr220-question.html)
seventythree 08-15-2013 03:07 PM
CDR220 Question
Is it true that if the AUX input is turned on using the user menu feature, the in-dash CD player gets turned off automatically?
In other words, one can either use the in-dash CD play or the AUX input?
TIA
tonycarreon 08-15-2013 03:22 PM
if you switch to AUX, the cd stops playing, yes. switch back to cd to listen to a cd...
BoxsterSteve 08-15-2013 03:22 PM
I can use both... I just have to toggle between with the ''S'' button. Aux souce or CD stop when the other input is chosen.
seventythree 08-15-2013 04:22 PM
Well for me, the S button used to toggle between the radio and CD. Now that I turned the AUX input on, it toggles between the radio and AUX. I was expecting for it to go radio --> CD --> AUX --> radio, but it won't go to CD anymore. :confused:
BoxsterSteve 08-15-2013 04:39 PM
I hate to ask, but there's a CD in the player, right?
Not trying to be a smarty...
seventythree 08-15-2013 07:27 PM
Well, I was certain there was a CD in it but I went and checked again just because you asked.
And now, it does go to CD mode and it plays! The S button is a little skippy. Sometimes it'll skip over the radio mode, and sometimes it skips the AUX.
I'll just have to remember to use a lighter touch when pressing on the S button.
Thanks for all the replies.
wawa 08-16-2013 03:33 AM
It's normal, it skip less use mode. You just need to double push the S to reach the less use mode.
Chris
