Old 08-12-2013, 05:37 PM   #1
heymanwatchthis's Avatar
Seat hack to add back support
I discovered a cheap and easy way to add some back support to the 986 seats.
My '01 986S has standard seats that I found very uncomfortable. Lower back always hurt after a very short while, I could not find a way to adjust it out.
Fiddling around with the seat I discovered the 'pad' on the backrest is attached at the top and bottom, open on the sides. You can see from picture that the sides can be opened with a slight pull.
To increase lower back/lumbar support, I cut a couple of pieces of cardboard to slide down behind the backrest pad. I experimented with various shapes and thicknesses, settled on two pieces of thick cardboard (box for shipping), one taller than the other to make support profile I wanted. Width is a little more narrow than the backrest pad so it slides down into the seatback, and to hide the cardboard.
The cardboard has just the right amount of flexibility and structure. If it wears down or I dont like it for some reason, is extremely easy to remove and replace with something else.
Now my seat is very comfortable with the just right amount of support.
If any of you find your seats lacking lumbar support, hope this helps.
heymanwatchthis is offline   Reply With Quote
Old 08-12-2013, 09:08 PM   #2
i did a similar thing with a manual blood pressure cuff. i can pump up the support or let it leak out as i please. pretty cheap, too. under $20.
silverboxter is offline   Reply With Quote
Old 08-13-2013, 06:56 AM   #3
I did the blood pressure cuff thing also. I found the child size worked best.
'99 black 986
Old 08-13-2013, 07:23 AM   #4
Wow great idea, I will try the blood pressure cuff.
Old 08-13-2013, 07:47 AM   #5
Pictures please of the blood pressure thing. Where did you hide the pump?
Pedrof is offline   Reply With Quote
Old 08-13-2013, 08:36 AM   #6
I let the pump bulb sit beside the seat by the hand brake. Remove the gauge, you don't need that part. With a little fiddling around you'll get everything where you want it. Sorry, don't have any pics handy.
'99 black 986
Old 08-14-2013, 02:45 AM   #7
haz
haz's Avatar
Anyone know which measurements to go for? I can see there are baby sizes also .. 8,5 cm x 19 cm
CONTEC Reusable Adult Cuff for Digital Blood Pressure Monitor Patient Monitor | eBay
haz is offline   Reply With Quote
Old 08-14-2013, 02:42 PM   #8
BYprodriver's Avatar
When I worked at Saleen Mustang 93-95 we installed Flo-Fit seats in the Saleens & most people ordered the optional lower lumbar support. This consisted of a plastic bladder & small squeeze bulb to pump up the bladder to the desired shape. These generic, purpose made bladders may be available if you search online.
Old 02-19-2020, 11:31 AM   #9
Finally lumbar relief
Been searching for this kind of relief for lumbar support for a while. Didn't realize you could get behind the back of seat back....... rolled up a hand towel put behind seat back my seat now fits me like a glove! Like a glove I tell ya.......t
Dave
1998 Boxster
1978 R100RS BMW Motorcycle 140K, 1 owner
WhiteyII is offline   Reply With Quote
Old 02-19-2020, 12:03 PM   #10
01 Basalt Metallic 986
JimmyBad's Avatar
https://www.amazon.com/dp/B00F5272FE/ref=cm_sw_r_cp_api_i_xqztEbFRXM4Z7
Pictures are also taken in a boxster.
JimmyBad is offline   Reply With Quote
Old 02-19-2020, 01:34 PM   #11
Corbeau has them, work great.
Hasbro is offline   Reply With Quote
Old 02-21-2020, 04:22 AM   #12
mikesz's Avatar
I used the patient monitor blood pressure works well
99 Porsche Boxster
Old 02-21-2020, 07:37 PM   #13
Qingdao's Avatar
Originally Posted by JimmyBad View Post
LOL perfect product placement.
'98 PP13B powered "RX986"
Qingdao is offline   Reply With Quote
