Old 08-06-2013, 06:10 AM   #1
Coffinhunter's Avatar
Clearcoat "peel"
While giving a good wash I noticed that there are a couple of small areas on the front bumper where it looks like the clearcoat is peeling. Kinda like skin after a good burn. All of the paint looks good still, but I want to stay ahead of it. Kinda OCD like that.
What is the best way to "fix" this, shy of a body/paint shop?
Old 08-06-2013, 06:36 AM   #2
Does it have any accident history? Don't see any good/perm solution short of a repainted bumper cover. Should be less than $600 for a quality job. Take photographs to document your "cosmetic" repair only for the next buyer.
Old 08-06-2013, 06:48 AM   #3
No accidents. One family car, so I know the history. The spots are REALLY small (like I said, I'm being a little OCD about it ), so I don't need to do anything, just want to.
Old 08-06-2013, 07:06 AM   #4
Take to a good body shop. Have them look at it. Maybe they can hit it with a coat of clear for a couple hundred bucks.
If they can do it, you remove the bumper cover (saving $$), clean out your rads and AC condensor, deliver the cover to the body shop, and return in a few days and replace the bumper.
Old 08-06-2013, 07:17 AM   #5
Are you using a power washer to clean the car?
Old 08-06-2013, 07:59 AM   #6
Kind of. I use it on the wheels, and on low setting to get the soap off. I don't use it on a high setting on the paint. I'm paranoid that would strip the paint right off. It's only 1,600 PSI at highest, and I get nowhere near that.
Old 08-06-2013, 08:03 AM   #7
That's what I thought. You may want to re-think this process.
Old 08-06-2013, 09:32 AM   #8
woodsman's Avatar
maybe it's stone chips in the clearcoat. Wax or repaint.
Old 08-06-2013, 09:40 AM   #9
Dr. Colorchip time?
Old 08-06-2013, 09:48 AM   #10
I thought of that, but the pressure I am using is less than ony of the self service places, or a drive through would be.
However, I will not be getting near the "peeling" area.
Old 08-06-2013, 09:49 AM   #11
Dr. Colorchip time?
What is this Dr. Colorchip you speak of?
There is no loss of color/paint
Old 08-06-2013, 09:51 AM   #12
It might be a stone chip, but there is no color loss.
Would a solid waxing "cover" that up?
By solid I mean detailed
Old 08-06-2013, 09:53 AM   #13
Post some photos.
Old 08-06-2013, 10:02 AM   #14
woodsman's Avatar
a chip in the clearcoat ONLY. The colour is the first stage than the clearcoat is applied. A good coat of wax will fill in the loss of surface height and add shine, just like a clearcoat does.
Old 08-06-2013, 10:51 AM   #15
Really? With all the wax/sealant on my car, it should look as big as the new 981.
Old 08-06-2013, 02:58 PM   #16
Not the best photo, but it's raining and had to do this in my garage.
It's about the size of a pencil eraser.
Old 08-06-2013, 03:46 PM   #17
This is fairly typical. Plastic bumpers simply aren't the best for holding paint.
It's not the end of the world. Either ignore it, or get it re-sprayed.
The alternative is to wait for your car to end up in a fender bender, then you get a new bumper on the house...
SOLD - 2002 Boxster S - PSM, Litronics, De-ambered, Bird Bike Rack, Hardtop, RMS leak...
fatmike is offline   Reply With Quote
Old 08-06-2013, 05:10 PM   #18
I thumped my front bumper on my Mazda 3 back in 2009. It was very minor damage so wasn't worth $800 to replace. I had that car for 4 more years waiting for somebody to hit it. Hoping every day. Never happened.
Old 08-07-2013, 12:37 PM   #19
woodsman's Avatar
It's possible to get a 'blow-in' which is where a pro sprays a little clear in a small area and then uses thinner or a special blending solvent to get the old and new clear to meld. Then it's buffed. Most would be unable to see the repair but you would!
DO NOT wet sand the problem area as clearcoat can be buffed to perfection but the base/colour coat cannot. You could wax it once a week for a few and see if it improves.
