-   -   Which brand rotors to get? (http://986forum.com/forums/boxster-general-discussions/47004-brand-rotors-get.html)
CrazyBoy 07-10-2013 10:22 PM
Hey guys, which slotted rotors should i get for my boxster s 2001? Original Porsche or?
Spinnaker 07-10-2013 11:20 PM
If you want slotted rotors, they won't be original Porsche. They only offer drilled rotors for a S.
Slotted rotors would be aftermarket.
black_box 07-11-2013 05:48 AM
You can get Sebro or Meyle high quality non OEM brakes pretty cheap from Pelican or eBay.... I saw a set of Brembo front rotors on eBay a few months ago for around $160... that's a deal too.
Whatever you do, be sure to get anticorrosion coated rotors OR hit the semi-conical rotor "hat" section where the lug bolts screw in with some high temp paint prior to installation. Otherwise they WILL turn a nasty shade of orange.
Be sure to use a) loctite and b) a torque wrench when installing all of your brake components.
WhipE350 07-11-2013 06:14 PM
Save yourself some money and get Balo. You can get them zinc coated for well under $100 a pair. They are made in Germany and I'm guessing are OEM to Porsche. I have them and they are great.
ChrisZang 07-11-2013 06:26 PM
If you want SLOTTED rotors (which are actually far superior to cross drilled rotors): I got a pair from R1Concepts for around $150
They were Zinc-coated and lasted forever
CrazyBoy 07-17-2013 09:02 PM
Found 2 models not sure if cheaper one will do, big difference in price...
Drilled Slotted items in 2001 Porsche Boxster Roadster S store on eBay!
ChrisZang 07-18-2013 05:01 PM
I think the "ELINE" were the ones I had
Worked great and were zinc - coated
ekam 07-18-2013 05:16 PM
Only the OEM rotors from Porsche have painted hats which prevent them from rust, otherwise you'd have to paint them yourself.
CrazyBoy 07-18-2013 07:26 PM
The Eline model seems nice for the price, how come the stop tech ones are 3x more expensive that's what i dont understand..
ChrisZang 07-18-2013 11:28 PM
Nope these rotors are zinc coated. No rust (albeit in California)
ekam 07-19-2013 03:35 AM
We use military grade salt on our roads here in winter. They eat thru zinc coating in one winter.
