Old 07-04-2013, 03:40 PM   #1
Rough idle and hesitation when I blip throttle
So I did my AOS and cleaned my MAF a couple weeks ago. Car still hesitates when I blip the throttle and when I first start it. It wants to die. After it heats up it runs better but not perfect.
Here's a vid at idle when I blip it. Is that sound normal? I'm guessing it is. But I wanted to post it to get your opinions. When I blip it, that's when it hesitates etc.
Other than that, I'm not sure where to look next
[/URL]
http://i1205.photobucket.com/albums/bb439/Matt_Dutz-Doots/583A5219-6415-48EB-AE79-951A256CB4B1-7919-000004BF1E634F98.mp4
bmx672 is offline   Reply With Quote
Old 07-05-2013, 11:22 AM   #2
woodsman's Avatar
be sure to let us know when you find the cure.
Old 07-05-2013, 03:33 PM   #3
So today I was going to clean the throttle body... But first I disconnected the MAF to see if the idle was better. It was. So I thought then maybe it was a bad MAF and I didn't need to clean the TB. Upon inspecting the TB I saw that the ring/clamp from the airbox to the TB was completely loose! I mean all the way loose! Maybe that was the cause??? I cleaned the MAF again and tightened the loose clamp and the car seemed fine! Only time will tell though. I has been intermittent. Since replacing the AOS. I hope that the loose clamp was the main problem and my idle and throttle response stays good!
