Old 05-29-2013, 09:27 PM   #1
Redmond's Boxster
Scream noise when starts up HELP!
Hi guys
On my 97' boxster, when I start it up it makes this sudden scream noise. It doesn't happen very often, probably 1 in every 10 start ups. It goes for around 1 second but it's a high pitched 'VVVVV' type of noise.
Also my temperature gauge is normal, but the red heat side flashes every now and them also during when I drive, it also happens 1 in every 7 start ups. I have topped up my coolant tank and it seems to be the right level and hasn't moved. Anyone know what the problem is??? Getting a bit worried about the well being of my beloved Porsche.
Cheers. From Australia
Redmond Boxster is offline   Reply With Quote
Old 05-30-2013, 05:43 AM   #2
DIY extremist
black_box's Avatar
If it sounds like "Ewwwwwwww!", then the starter bendix drive is not disengaging -- my car did same. Squirt some lithium grease in there.
If it sounds like"thwacka thawacka thwacka", it's a cam chain pretensioner spring that's not strong enough -- replace with new spring or live with it -- only an issue when starting and oil pressure is zero.
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
black_box is offline   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions, Inc.
Copyright 2024 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
