-   -   Cayman S spoiler installed (http://986forum.com/forums/boxster-general-discussions/46156-cayman-s-spoiler-installed.html)
cheetah 06-19-2013 10:33 AM
I did debate whether to leave the diffuser area as a matte finish (like my front lip) but I am glad that I had it all painted the same way. It is a great looking part.
I just swapped from the aftermarket LED clear side markers to the OEM "euro" ones that are a smoked clear. I bought some multi-directional LED's to fit in there and they fit nicely. They match the smoked LED tails perfectly.
Side skirts... I have thought about them also. Maybe in the future. Too much in car parts lately with this and the Audi.
Let us all know if the Cayman assembly works well. How much did that assembly cost?
Thanks everyone for the kind words.
Here is a shot of the front. Now that the part is fit correctly, I am going to put the plastic deflectors for the radiators back in (they will have to be trimmed or the openings will not match well. I don't like the look of most of the "grills" since they all look like they came from Home Depot.
http://986forum.com/forums/uploads01/side1371663093.jpg
heliguy 06-19-2013 11:08 AM
What are the "Plastic deflectors" you are putting back in? I paid 170 for the spoiler like you did. the lift mechanism is another 170, but i don't have a lathe to turn the old ones on like you did. I figure it will be a simple swap.
cheetah 06-19-2013 11:30 AM
http://lh5.ggpht.com/_Zt3oBgkIEjA/S3...0/IMG_0102.JPG
particlewave 06-19-2013 11:54 AM
Isn't there a spoiler kit for the 986 that bolts to the existing lift mechanism?
particlewave 06-19-2013 12:01 PM
Yeah, this one...
Unpainted and know nothing of the quality, though.
The Radium King 06-19-2013 01:09 PM
or you could go to post #9 in this thread ...
Perfectlap 06-19-2013 02:13 PM
I also ordered from Precision Porsche. At the time I think they were one of the few sites who offered the 996.2 GT3 side skirts for the Boxster which were not offered by Porsche. And I wasn't crazy about the 996.1 GT3 skirting which was available in factory fit.
When the skirting arrived one side was shorter than the other. Not bad enough to go through the hassle of a truck freight return but a good mm or two gap past the rear wheel fender on the passenger side. But the cost was very low, like barely $300.
heliguy 06-19-2013 06:54 PM
Particlewave, I considered that one but I have heard the fiverglass is thin in some areas...plus I think the Cayman one is a bit larger. Cayman R would make it like a whaletail.
heliguy 06-19-2013 06:56 PM
I went to post #9, its about bumperettes.
The Radium King 06-19-2013 08:30 PM
golly, I must've failed counting. hold it, no I didn't ...
now, if you want a 3/4 shot, in the evening light, painted magenta arctic metallic on the third month of butsi's death, with a lengthy description of the fasteners used to hold it in place, then I can't help you ...
heliguy 06-24-2013 04:02 PM
Received my Cayman S spoiler today. does yours overhang the tail lights a bit? Did you overcome that just with fine height adjustmants
jaykay 05-01-2014 06:46 PM
How did your install work out?
heliguy 05-01-2014 09:13 PM
It worked out just great. I love the new look.
http://986forum.com/forums/uploads01...1399003851.jpg
http://986forum.com/forums/uploads01...1399003913.jpg
http://986forum.com/forums/uploads01...1399003964.jpg
http://986forum.com/forums/uploads01...1399004005.jpg
jaykay 05-01-2014 09:33 PM
Okay! Did you use the 987 spoiler mechanism; if so what parts did you use?
I see some sort of added lip at the rear of the spoiler opening.....is that part of your original bumper....oh it is a 2003? Does one need this year bumper to make it work?
Did you have to adjust things like retract stops ? Any difficulties?
heliguy 05-01-2014 09:55 PM
It was a direct bolt on using the 987 lift mechanism. I'm not sure if you need the facelift bumper or not.
Timco 05-02-2014 06:12 AM
Dude. You're Batman. Sweet mod!!!!
heliguy 05-02-2014 06:34 AM
Thanks. It was not that expensive and really adds to the uniqueness of the car.
jaykay 05-02-2014 09:48 AM
Rear wing configuration and stability
Yes, it really looks great! I am surprised you are not hitting the tail lights on retract....How on earth did you prevent this? Looks really good. You could have even gone with "the Wing" I linked up below. How does it feel to drive at speed? Any stability changes?
Has anybody got a handle on the effect on aero with the removal of the flat blade?
From the looks of things the blade would reduce the lift created by the back upper surface of the car by outright airflow disruption while creating a fair bit of drag.
But this drag would look to be off set by preventing some "suction" airflow drag behind the car.
The Cayman wing looks to rely on down force from a wing shape than airflow disruption and of course is made to work with the Cayman rear deck.....How would this compare with the Boxster.
Any flow visers out there?
heliguy 05-02-2014 10:54 AM
I adjusted it so it sits just above the taillights (there is about a 1mm gap)
I thought about The Wing, maybe someday.
I don't drive fast enough to notice any lift!
markskyline 05-02-2014 01:46 PM
Heli did you take photos of the process? Maybe a DIY thread? :cheers:
heliguy 05-02-2014 04:16 PM
No photos. I was in a hurry to get it installed. Basically you just order the wing and the lift mechanism (I got mine from Cayman Parts Direct in Chicago), take the carpet out of the trunk and its an easy part for part swap.
peterek 05-03-2014 04:42 PM
Best looking spoiler on 986 ever!!
mikesz 05-19-2015 07:15 AM
I think it looks good when retracted, sort of a mini whale tail but wouldnt spend 2-3 k for it.
heliguy 05-19-2015 03:55 PM
Who spent 2-3k?! The entire assembly with motor and all was about $200.
EJ-Fresno 05-19-2015 08:36 PM
Would it be possible to get the part numbers please?
Thanks!
heliguy 05-20-2015 04:14 AM
Thanks!
Caymanpartsdirect.com
987.504.109.00 (Spoiler drive mechanism)
987 504 619 00 (Upper/Lower spoiler assembly)
mikesz 05-20-2015 05:21 AM
HMM Did you put this on a 986 or 987? I have a 99 and considering doing this mod.
heliguy 05-20-2015 04:30 PM
It's on an 03 986. I'm sure the lift mechanism on the 99 is the same but the bumper and trunk lid are slightly different so I'm not sure about the fitment.
emore93 08-05-2015 08:57 AM
I realize this is an older thread but I just found it and thought it was a great idea.
Heliguy - How did you create the gap between the taillights and the spoilers (washers)?
I would also be interested in hearing what effect is has to the down force.
Like you, I don't drive anywhere near the speed where that would really be noticeable. Hard to get it up past 130mph here in the city.
epapp 08-05-2015 09:12 AM
Another bump: did anyone install this on a pre-facelift car ('99?)?
Top_Ramen 08-05-2015 11:06 AM
I've got mine on my "pre-face lift" 1999. No washers were needed. Bolted right on along with the lift mechanism, including wiring.
http://s18.postimg.org/5f80k6v9l/20150624_064015.jpg
http://s17.postimg.org/ptm4i6rof/20150624_064108.jpg
http://s13.postimg.org/bmd5tilo7/20150624_064347.jpg
EJ-Fresno 08-08-2015 08:34 PM
So one just buys the Cayman lift mechanism + spoiler, removes the Boxster assembly and simply bolts on the new assembly? No need to rework any parts? Just adjust clearance for the trunk?
Thanks.
Top_Ramen 08-08-2015 09:07 PM
Thanks.
Yup:cheers:
...you can use the existing 986 lift mechanism but will have to do some grinding on the top's of the posts. OP mentions it a bit in his first post & post #16 too
epapp 08-09-2015 02:56 AM
I really like the look. Except the gap that exists between the trunk and rear bumper when the wing is down. Can you snap some more detailed pics of this area of you don't mind?
EJ-Fresno 08-09-2015 08:50 AM
Exactly what I wanted to ask :cheers:
particlewave 08-09-2015 09:12 AM
Good luck. I've been asking for years and can't even get anyone to admit to it, nonetheless take pictures :rolleyes:
Top_Ramen 08-09-2015 09:15 AM
. Running into the garage now and snapping some better detailed pics.
:edited: pics below
Top_Ramen 08-09-2015 09:35 AM
sorry for the filthy car. haven't washed it in almost 2 months
http://s29.postimg.org/fv69aj753/20150809_112822.jpg
http://s4.postimg.org/szdm6cqbh/20150809_112842.jpg
http://s2.postimg.org/qnruu16jd/20150809_112919.jpg
http://s18.postimg.org/jkplbdznd/20150809_112944.jpg
http://s16.postimg.org/yvsq7dn1h/20150809_113047.jpg
http://s29.postimg.org/og46fg6p3/20150809_113123.jpg
Top_Ramen 08-09-2015 09:53 AM
This is with the 987 lift mechanism. I'm not 100% certain, but I believe it sits a couple millimeters lower with the factory 986 lift mechanism after its been modified to accommodate the Cayman S spoiler.
EJ-Fresno 08-09-2015 10:02 AM
Well it's not that bad, even on close view. I assume look is even better from wide range?
