Old 04-01-2013, 12:05 PM   #1
repair defrost tab?
I recently picked up a used 03 top/frame to update my 01 top, which is starting to get long in the tooth. After getting home with it I noted the rear window defroster has the electical connector tab broken free of the glass on one side. Can this be fixed? If so, how? Thanks all.
Old 04-01-2013, 12:53 PM   #2
I have the same detachment on my passenger side.. looking for answer.
ohhh my is offline   Reply With Quote
Old 04-01-2013, 01:13 PM   #3
Nimbus117's Avatar
Wasn't just me then. Mine broke last year, I got some of this stuff and it works fine now:
Frost Fighter 2000 Tab Repair Kits
2003 Boxster 2.7L
2010 Civic Type R
Nimbus117 is offline   Reply With Quote
Old 04-01-2013, 04:23 PM   #4
thx
Nimbus that looks perfect, and with the positive rec from you I'll give it a try. Thanks!
Old 04-01-2013, 04:42 PM   #5
I've used a similar product on my dd and it works well. Has held up for 6 years as of now.
Old 04-02-2013, 12:53 AM   #6
Nimbus117's Avatar
It's an epoxy with a very high silver content so it conducts electricity well. There are cheaper products but there are quite a few amps flowing through it so avoid them. Best to do it on a warm day and even then you still have to use a heat gun or hairdrier to cure the epoxy for an hour.
The tube is sufficient to repair a 100 tabs!
2003 Boxster 2.7L
2010 Civic Type R
Old 04-02-2013, 09:23 AM   #7
ccstud17's Avatar
same problem here. id be willing to pitch some $ for a 986forum.com circulating defroster epoxy tube! lol
ccstud17 is offline   Reply With Quote
Old 05-15-2013, 06:06 AM   #8
update
Thumbs up! Tried this stuff, seems to be the fashizzle, works exactly as promised, with taping looks very professional, detectable only by change in color as compared to original. Thanks to Nimbus for the heads up!
May try this for cold soldering to replace rechargeable batteries in other applications.
