Old 04-04-2019, 03:35 AM   #661
Heiko's Avatar
Originally Posted by Kuehjo View Post
Hoping that you’ll be able to help me as well...
2000 Boxster S
Becker 1
CDR 220
Type 4362
Serial #Y5021528
And Mahalo in advance!!
Jonathan
try 9124 and if that doesn't work the second option is 9122
Heiko
Previously owned:
Old 04-29-2019, 02:25 PM   #662
And yet another one
Really hoping you can help me out! Thought I had a battery tender keeping the juice flowing via the cig lighter during a battery swap....found out I was wrong - must have blown the fuse!
2000 Boxster
Becker CDR220
Type 4462
Serial Number: Y5035596
Thank you!!
kevinp74 is offline   Reply With Quote
Old 04-29-2019, 07:22 PM   #663
Heiko's Avatar
Originally Posted by kevinp74 View Post
2000 Boxster
Becker CDR220
Type 4462
Thank you!!
Try 9412 and if that doesn't work try 9410 (the first one should do though)
H
Previously owned:
Old 04-30-2019, 04:54 AM   #664
Thank you!!! Much appreciated!! 1st code worked like a champ!!
Old 04-30-2019, 06:30 PM   #665
Heiko's Avatar
Glad it worked :-)
Enjoy the tunes :dance:
Previously owned:
Old 05-16-2019, 02:33 PM   #666
Radio Code for a cdr220
Hey thanks in advance for the radio code
Model BE4462
Serial x5021977
Type cdr220
pwalmsley is offline   Reply With Quote
Old 05-17-2019, 04:26 AM   #667
Heiko's Avatar
Model BE4462
Serial x5021977
Type cdr220
Try 5037 first or 5035 second :-)
Cheers
Heiko
Previously owned:
Old 05-19-2019, 03:45 PM   #668
Radio Code
Help!! I need radio code for CDR 220, Type 4462, Ser#: X5031644. Any help will be appreciated.
Mrjusti is offline   Reply With Quote
Old 05-21-2019, 03:49 AM   #669
Heiko's Avatar
You can try 5451 first and if that doesn't work try 4451
H
Previously owned:
Old 05-23-2019, 12:00 AM   #670
please help!!!
Hi, i need help, my radio type is BE4462 and serial: Y5036228.
Thanks in advice.
micsiw83 is offline   Reply With Quote
Old 05-23-2019, 01:09 PM   #671
I need a code. The dealership is a bit slow responding! CDR 220 Y5047411
Thanks for your help! This is great. I will participate in this forum now that I have found it!!
beggroll is offline   Reply With Quote
Old 05-23-2019, 01:13 PM   #672
Code Help!
I have a code requirement please! Y5047411 CDR-220
Dealership has been a bit slow in responding. Now that I have found it this is a great forum to participate in!
Last edited by beggroll; 05-23-2019 at 01:15 PM. Reason: repeated it! Didnt realize it!
Old 05-27-2019, 03:57 PM   #673
Heiko's Avatar
Thanks in advice.
try 4872 first and if that fails try 4772
Heiko
Previously owned:
Old 05-27-2019, 03:58 PM   #674
Heiko's Avatar
try 3215 and if that fails try 3214
Heiko
Previously owned:
Old 06-04-2019, 06:48 AM   #675
CDR 23 needs a code.
I'll be changing out my battery for the first time this week on my 2004 Boxster 550 anniv S.
It was installed 3/2009 and still puts out 13+ volts at rest!!!
VIN # WPOCB29834U661077
I don't know what to look for on the label in the frunk under the insignia for the radio code. Lots of letters and numbers.
Radio manual indicates it's a CDR 23, with brand name unmentioned.
It's a Bose system.
How do I make sure I'll be able to use the radio post battery change?
Thanks in advance
newcider is offline   Reply With Quote
Old 06-05-2019, 07:02 AM   #676
All's well.
Battery swap only caused loss of clock time.
All other settings remained intact.
The radio works.
Old 06-05-2019, 11:45 AM   #677
Heiko's Avatar
Originally Posted by newcider View Post
All's well.
The radio works.
Yup the newer ones retain the code via the canbus to the ECM.... it wouldn't work if you pulled it and plugged it into a different car but as long as it stays in the same car it will work without putting in the code :-)
Previously owned:
Old 06-13-2019, 05:56 AM   #678
Radio code help
Hi Heiko,
Would you please help me with a radio code? Got blocked after a battery swap!
Model cdr-220
Type 4462
Serial number 15087955
Rafael
Rafaluz is offline   Reply With Quote
Old 06-13-2019, 05:53 PM   #679
Will there be cake?
tonythetiger's Avatar
Originally Posted by Rafaluz View Post
Hi Heiko,
Model cdr-220
Type 4462
Rafael
Dude. Search on the forum. Someone here can help with the code if you have the serial.
Tell us it worked
Old 06-17-2019, 09:43 AM   #680
Heiko's Avatar
Hi Heiko,
Model cdr-220
Type 4462
Rafael
Try 7056 first and if that fails try 7055
Cheers
Heiko
Previously owned:
