-   -   testing battery draining question (http://986forum.com/forums/boxster-general-discussions/45409-testing-battery-draining-question.html)
rosenfe 05-03-2013 08:28 AM
im having a dead battery show up in the last few weeks.i plan to test with multimeter between positive cable and battery for draw.does disconnecting positive terminal require resetting radio code.what do i do if i cant find my code.?
JFP in PA 05-03-2013 08:48 AM
Go to RennTech.org, they have a specific forum section where you can request the code.
leknus 05-03-2013 02:01 PM
Radio Code
What model is your radio? My CDR23 does not require a code.
thstone 05-03-2013 04:10 PM
Get the serial number and type by turning on the radio and pressing the "TP" button for several seconds. Then use the right hand knob to scroll through the info and write it down. Then post it on this Renntech site and Loren will post up your radio code.
Lost Radio Code - post your request here - 986 Series (Boxster, Boxster S) - RennTech.org Forums
rosenfe 05-03-2013 05:47 PM
i checked with renteg forum,apparently 03 s does not need code if its original radio.
