-   -   Boxster defect: white smoke (video) (http://986forum.com/forums/boxster-general-discussions/45017-boxster-defect-white-smoke-video.html)
14skillz 04-24-2013 11:03 AM
Yesterday while driving 5000\6000rpm a big plum of white smoke appeared in rear-view mirror. Immediately stopped the car.
No warning lights, enough water and oil.
It was recently serviced (march 2013)
Check the vid:
https://dl.dropboxusercontent.com/u/29805910/IMG_1076.MOV
You guys have any idea what's the problem here ?
Mark_T 04-24-2013 12:36 PM
Yes. Try searching the forum using the key words "air oil separator" and you will find all kinds of information about your problem. Once you've read through the many posts on this topic, please post back if you still need further information. Welcome to the forum.
14skillz 04-24-2013 12:53 PM
tnx, will look into it
nieuwhzn 04-24-2013 09:56 PM
Don't worry, well known issue.
$120 buys you a new AOL.
You can install it yourself, medium difficult, mostly just tedious.
Spinnaker 04-25-2013 04:08 AM
He doesn't need internet access (AOL), he needs a new Air Oil Separator (AOS). :p
14skillz 05-07-2013 12:12 AM
Replaced the "air oil separator", problem solved !
Tnx for the tips!!!
jovie 05-07-2013 07:21 AM
also try checking if there's a large vacuum when you open your oil cap while the vehicle is running. if there is, it's your AIR/OIL SEPARATOR! replace it asap! its either spend $120 or $4000. it will take you about 1-2 hr DIY.
14skillz 05-07-2013 09:01 AM
Hope this one will last for a couple of years, this was my first air/oil separator in 124k miles :-)
