Old 12-11-2005, 10:47 AM   #1
slogans7's Avatar
A screw in the boot
Why, you filthy minded so and so! No, I found these in my boot this morning and can't figure out where they came from. Any ideas?
2002 Triple-Black Boxster S
slogans7 is offline   Reply With Quote
Old 12-11-2005, 11:30 AM   #2
bmussatti
Guest
Posts: n/a
In your shift boot? Please elaborate.
Old 12-11-2005, 12:07 PM   #3
I'm thinking he's using the word "boot" for the trunk.
These little gizmos hold in your carpet, keep things in place and are used all over your car. Look under the front bumper and in your wheel wells and you'll see more of them. Look around and you'll see where it came from inside your trunk (or boot, as you call it).
Old 12-11-2005, 03:57 PM   #4
slogans7's Avatar
Yes, the trunk.
Old 12-11-2005, 04:18 PM   #5
Tool Pants is offline   Reply With Quote
Old 12-12-2005, 05:14 PM   #6
deliriousga's Avatar
The one on the right is used to hold the side covers on the trunk. That particular one looks like the one that screws down the cover over the tail light access.
The one on the left looks like one of the push locks for the side covers. If it is, you should have a larger plug that has a hole in it. That pin goes in the hole to make the plug hold tight from behind.
1966 Wife White/Brown Top
