Old 12-12-2005, 04:56 AM   #1
2006 Boxster 1st Oil change and odd noise
My G/f has an '06 Boxster with 4500 highway miles...daily driver.
She recently noticed an odd fluttering noise that comes from behind the driver...sounds kinda like if you had tin foil fluttering between the spokes of a bicycle wheel.
I searched the site and came up w/this possible explanation for the noise. She is also experiencing a loss of power.
"I think the sound is likely cavitation, which basically occurs when a pump is pressurizing oil with air in it or theres not enough oil feed to a pump. If the relief valve is opening too early or too much in cold running (ie higher viscosity oil which = higher pressure, and also reluctance to flow into the pump) its possible the pump is being starved of oil, or being fed oil with air in it.. The air is compressed (assuming for the mo that oil is incompressible) and implodes which over time will diesel (or burn) the oil, and will reduce the oil life, increase the acidity of the oil and damage components, making matters worse...
When cavitation occurs (particularly on leading edges of pressure equipment, ie pump lobes/gears) the material in these areas is damaged causing a drop in performance and "sealing" making the matter progressively worse. This may explain why a new oil pump helped for a short while, but eventually the problem came back..."
She's taking the car to the dealership tomorrow...about a 160 mile round trip so I don't want the time wasted and suggested she have the oil and filter changed...in case they cannot find any problem causing this odd noise I'd like to see what the filter looks like inside at least.
I searched but had no luck locating at what milage the general consensus agreed on was best for an initial oil & filter change for a daily driven Boxster. 20K miles seems absurd to me. The car is driven an average of 500 miles per week....90% highway.
Better to change it now...or wait until what milage for the initial oil/filter change?
If there is a link to an answer for this that would be much appreciated.
KShep is offline   Reply With Quote
Old 12-12-2005, 05:00 AM   #2
bmussatti
Posts: n/a
The general recommendation for oil (and filter) changes is after the first 1,000 miles and then every 7-10K thereafter. Using Mobil One 0W40.
Take it to the dealer to fix/find the noise you are hearing. Could be something worked loose too.
Old 12-12-2005, 05:43 AM   #3
Thanks.
She is fighting me on this oil change....the salesman to her no service recommended until 20K miles. It doesn't get very cold here in SE GA...0W40 will work in warmer climates o-K?
2006 Porsche Boxster Atlas Gray Metallic
2006 Lexus IS350 Tungsten Pearl
2004 Nissan 350Z GReddy Twin Turbo
http://img259.imageshack.us/img259/3558/hhiz503xt.jpg
Old 12-12-2005, 06:37 AM   #4
Brucelee's Avatar
Talking
On the oil change, I think it depends on the future of the car.
If she is likely to keep this as a long term car, my thoughts are oil changes every 7500 miles. Based on what data I have seen on M1, that is when it starts to go south.
If she is a three year owner type, this is over kill and the 20K is likely OK.
On the weight issue, I think the 0-40 is fine. However, if it were me, I might run Castrol 5-50 in the South.
Old 12-12-2005, 07:48 AM   #5
Damm...sorry, I didn't realize that sig pic was gonna be so big.
She puts 22K miles per year on her car and the Porsche is a long term vehicle. If it's o-k to wait another 3K miles before changing out the oil/filter...great. But since the car is going to be over there anyway I will probably spend the $300 and get it done now.
Old 12-12-2005, 08:04 AM   #6
bmussatti
Posts: n/a
Kshep, your Z looks very nice!
An oil & filter change should be around $200 max. I've never heard of $300. Some places in the Chicago area are $110.
Have you checked the oil level recently? Wonder what that noise problem is. Let us know when you find out. Thanks.
