Old 04-15-2013, 11:12 AM   #1
cleaning engine question
first time i opened engine compartment this weekend to look around.engine is dirty with grime.how best to clean it.is useing pressure washer at self car wash a no no?
rosenfe is offline   Reply With Quote
Old 04-15-2013, 11:25 AM   #2
i would say no, because of where it is (inside the cabin area), what you need to cover (alternator and any plugs), and if anything happens (hopefully not) you'll need to be able to diagnose it on the spot, which isn't that fun at a car wash (from experience).
though, if you're adapt at power washing MRWD engines, go for it.
cameronzero is offline   Reply With Quote
Old 04-15-2013, 01:18 PM   #3
Just use a strrong solution of Dawn dishwashing liquid in a spray bottle, wet everything out except for the obvious electronics, brush the really dirty areas and then use a garden hose to rinse.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 04-15-2013, 03:04 PM   #4
AKnowles's Avatar
I used Simple Green at full strength and a hose with a "gentle shower" to clean it off. Worked great. Fired right up afterwards.
Old 04-15-2013, 06:08 PM   #5
I used this method. 1/2 Dawn & 1/2 water in a spray bottle, let it soak a few minutes then rinse with the garden hose. Everything came really clean. Start the engine & let id idle a few minutes to dry.
Bryan topping is offline   Reply With Quote
Old 04-16-2013, 08:42 AM   #6
BruceH's Avatar
I used Orange Cleaner. Spray, let sit, rinse, repeat! I worked the stubborn areas with more cleaner and a rag. I used very gentle water from the open end of the hose, no spray attachment.
Before:
After:
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 04-16-2013, 12:27 PM   #7
rp17's Avatar
Was there a muddy swamp under the car when you were finish? I took a dry rag and cleaned it because i couldn't leave it like that. Will get back in there with the hose. That looks nice and clean now Bruce.. Thanks for posting the pics.
Old 04-16-2013, 12:36 PM   #8
BruceH's Avatar
Yes, there was a bit of dirt on the driveway when I was done but a quick shot of the hose and it was gone!
DEPO Tail Lights
Old 04-26-2014, 11:29 PM   #9
same deal with me. I was checking the air filter, first time in the engine compartment since I bought the car. very dirty. looks mostly to be dust, so that is good. going to clean it tomorrow.
Plan is simple green and hose in the driveway. doesn't need to be spotless, but I would like to give it a rinse.
I have heard people freaking out about the prospect of cleaning an engine. back in the day I would cover the distributor with some plastic and a rubber band, but other cars I just hose them down while at the car wash. never had an issue. the only problem is, of course the proximity of the open interior. I'll do this one at home and tape and plastic off the areas around the engine compartment.
kiyakubuke is offline   Reply With Quote
Old 04-26-2014, 11:43 PM   #10
rdass623's Avatar
sounds like a project for tomorrow, also while the engine cover is out, I may as well paint the carpet. my carpet is looking a bit faded.
2005 Porsche Boxster S, 2000 Porsche Boxster 2.7L Base, 2000 Mazda Miata LS Supercharged, 2010 Toyota Tacoma TRD Off Road
Previous Vehicles: 2005 Ford Mustang GT, 1986 Alfa Romeo Spider, 1971 Alfa Romeo GTV, 1999 Ford Mustang
1977 Toyota Celica GT
rdass623 is offline   Reply With Quote
Old 04-27-2014, 05:28 PM   #11
what are you using to paint the carpet? how does it effect the feel of the carpet?
Old 04-27-2014, 05:34 PM   #12
before and after of engine cleaning
Old 04-27-2014, 11:41 PM   #13
saintdrug's Avatar
Send a message via Skype™ to saintdrug
how do u open the engine lid?
Best Regards,
Chris Abou-Chabké
www.blackhatethicalhacking.com
Boxster 2.7 2002 with Bose Proud Owner
saintdrug is offline   Reply With Quote
Old 04-28-2014, 05:59 AM   #14
search is your friend
'99 black 986
Old 04-28-2014, 09:12 AM   #15
here's a good video on it.
Porsche Boxster S - 986 Remove Engine Cover - Replace Air Filter RiversidePCA How To - YouTube
Old 04-29-2014, 07:31 PM   #16
linderpat's Avatar
those results look great. On my list.
Ed
Pittsburgh, PA
78 5 spd 928 Blumaxx (in Hemmings S & E issue #100)
85 928S garnet red stock daily driver
06 Mustang GT Legend Lime and modified to go even faster
linderpat is offline   Reply With Quote
Old 04-29-2014, 10:14 PM   #17
Pdwight's Avatar
I would like to know also
I need to re dye my carpet
