Old 04-14-2013, 07:54 PM   #1
I am my own mechanic....
Timco's Avatar
Shok talk....
So I always assumed the "pssssst" when going over larger bumps were from the fine, performance shocks and maybe even part of the PSM.
Then I woke up, read a thread that talked about these shocks being blown and having air in them and making that sound.
Frack.
So, if I'm not a track guy, what can I expect to feel different in replacing both rears with stock shocks vs aftermarket performance? What's the inbetween? What's the best source for a reasonable priced shock? It's my daily driver.
'08 VW Touareg T-3 wife's car
Old 04-14-2013, 08:03 PM   #2
darknight's Avatar
LOL, Sometimes the more one reads online, the more paranoid one becomes. If you don't believe me, google a couple of symptoms of the common cold and you may think that you could have something far more severe.
I would think what you are describing is the normal damping function of the shocks. When they fail, you will generally experience a car that will oscillate up and down or else they will leak fluid. If your car is not doing either of those two things, then I would save the money for something else.
darknight is offline   Reply With Quote
Old 04-14-2013, 08:54 PM   #3
Timco's Avatar
No leaks, just the "psssst" over medium + bumps.
Something that doesn't need to be replaced???????????????
Car rides great, not a singe ride issue.
Old 04-14-2013, 09:21 PM   #4
darknight's Avatar
If there are no ride issues, no leaks, and it was my box, I'd forget about it.
Being particular about cars, I can understand your concern; however, both of the 986's that I have driven, made some noise when going over moderate bumps. Almost like the "pst" noise that a can of spray paint makes when you quickly press and release the top. It's most noticeable when the suspension travels over a speed bump or a driveway approach, in my experience.
Old 04-14-2013, 09:46 PM   #5
Timco's Avatar
Yes, this exactly. I'm not looking to swap out every possible part, but am particular about keeping this car running right. The U/D pulley sounds like a worthy fix, but I'm not sold on desnork and delete cat pipes. I don't think all that time & effort is worth 10 HP at most....
Old 04-15-2013, 05:54 AM   #6
jacabean's Avatar
you have an 04 so there is no de- snork needed. a high flow air filter is about all you need there. there is a lot to be gained with the delete pipes. first is a good bump in power , you will loose a good 30 pounds of weight and with the cats gone it makes working under the car much easier because of all the extra room and easy removal . don't forget you also get a more porsche like exhaust sound since you already have the factory sport muffler.
Old 04-15-2013, 06:02 AM   #7
Timco's Avatar
Thanks. I will look back into this.
Old 04-15-2013, 08:46 AM   #8
ccstud17's Avatar
BOOM! read this. mainly post numero uno! you dont have to believe hearsay, but cannot argue with a dyno result! (on our own site ) Finally: Dyno charts of de-snorked 986S!!!
Stop lights timed for 30 MPH, are also timed for 60 and 90 MPH!
ccstud17 is offline   Reply With Quote
