Old 04-04-2013, 02:37 PM   #1
tanque55's Avatar
loose front end
At about 90 mph I feel the front end getting a little loose, steering gets some play in it. Up to that speed it feels good. I haven't gone faster due to this. Any idea where to start with this problem.
tanque55 is offline   Reply With Quote
Old 04-04-2013, 02:46 PM   #2
I think that what you are experiencing is normal. The front end does loosen up a bit at high speeds. Feels great at 120
Old 04-04-2013, 04:10 PM   #3
jacabean's Avatar
the front end gets a little soft up in speed as long as there is no vibration or shimmy shake all is good. i did 135MPH in mine once upon a time .
Old 04-04-2013, 04:39 PM   #4
BYprodriver's Avatar
Weak struts is where I would start. How many miles on the car? Has the original ride height changed? The front nose should be level or slightly pointing down.
Old 04-05-2013, 03:31 PM   #5
tanque55's Avatar
It's a 2002 S with 39K miles on it. Would the control arms contribute to this at all? Glad to hear that it is not unusual to get a Little soft up front. Besides it's not the top speed but getting there that is the most fun.
Old 04-05-2013, 03:43 PM   #6
With that mileage your struts should be ok unless any are leaking fluid.
Try filling the gas tank full & putting some weight in the front trunk, (40-50lbs) to lower the nose slightly & see if your problem improves.
Old 04-05-2013, 04:17 PM   #7
Steve Tinker's Avatar
Tanque.... worn bushes on both the front control arms (also called coffin arms) and the transversee arms can significantly affect your strait line stability.
Late last year I found my 55,000 mile S getting "vague" at highway speed and steering input a little sloppy. I checked all bolts / roll bar bushes, replaced drop links & steering rod arms etc, etc but to no avail. Then last month I bit the bullet & replaced all the control arms and transverse arms with new (TRW) replacements. I knew within 500 meters that I'd found the problem - no more vagueness. Steering nice and crisp with good turn in after the alignment was done.
Interestingly, when I removed the old arms from the chassis, there was no perceived sloppiness in the bearings - looser than the new arms but nothing drastic....but I still don't know if the faulty bushes were in the control arms or the transversee arms. Anyway they're all in the scrap bin now....
2001 MV Agusta F4.
Old 04-06-2013, 06:16 AM   #8
tanque55's Avatar
Thanks Steve. I have the new control arms sitting on my work bench right now, so I'll change and let you know.
