Old 03-16-2013, 03:07 PM   #1
wrong oil filter
i was changing my oil today. i bought a filter from the internet (sad to admit..ebay). when i removed the old filter, the new one didn't fit. the inner opening was too small on the new one. i specifically ordered a filter that supposedly fit the boxster. figured i made a mistake by buying it on ebay, i went to autozone and bought another one. however, when i got home, i realized i had the same problem. the dealership was already closed so i just reused the old filter. but has this happened to anyone else? i normally buy it from suncoast or dealer..now learned my lesson.
-Tuan
tuanle16@juno.com
tuanle16 is offline   Reply With Quote
Old 03-16-2013, 03:38 PM   #2
The OEM style filter cartridge is a "force fit" over the center because it uses treated paper end caps. That is way it creates a seal.
Old 03-16-2013, 04:11 PM   #3
Idaho Red Rocket 3's Avatar
Ditch those crappy flat paper end filters. Get a NAPA Gold. Very nice filter. Well made and has plastic ends.
2000 Boxster S
Old 03-16-2013, 04:31 PM   #4
you know...i thought that and even tried it. but it did not fit. the inner tube was too small to fit the lip in the casting. does that make sense? it was a completely different size than the one that i removed (and reused).
-Tuan
tuanle16@juno.com
Old 03-17-2013, 05:03 AM   #5
mountainman's Avatar
I use a couple of german made filters and they both have to be forced on. Get a bigger hammer.
mountainman is offline   Reply With Quote
Old 03-17-2013, 06:16 AM   #6
recycledsixtie
recycledsixtie's Avatar
I buy my oil filters from Pelican Parts. I don't go cheap on this kind of thing. They need very little force to get the filter on. I have been very satisfied with Pelican Parts. They have good quality products and what I think as good prices.
Old 03-17-2013, 08:21 AM   #7
Been using the Hengst filters from Pelican - never a problem.
'99 black 986
Old 03-17-2013, 10:02 AM   #8
I use Pelican's as well and never had an issue (or even thought one existed as I've used Pelican since owning the car). Good to know!
stateofidleness is offline   Reply With Quote
Old 03-17-2013, 02:04 PM   #9
Go get a NAPA Gold number 7211. Great filter. You can change the filter without changing the oil again. You will like it. I buy several at a time when NAPA has their filter specials. I think I paid 9 bucks each for the last batch of 4.
2000 Boxster S
Old 03-17-2013, 04:18 PM   #10
how do you change the filter without changing the oil? is there some sort of closed valve when the engine is off? i would assume that as soon as i take off the filter canister, the oil would just pour right out.
-Tuan
tuanle16@juno.com
Old 03-17-2013, 06:27 PM   #11
I put the back of the car up on ramps to get under the engine bay. With a drain pan under the filter housing, remove it. Yes a small bit of oil will come out but nothing to worry about. Change the filter and put it back together. Put the car back down flat, check oil level. Top up as needed.
2000 Boxster S
Old 03-17-2013, 06:34 PM   #12
thanks red
-Tuan
tuanle16@juno.com
