2001 porsche boxster convertible engine swap
Ok so basically heres what I want to do and I want to do it myself I have a 2001 porsche boxster 2.7 liter I want to upgrade to a 996 3.6 liter basically I'm aware that I have to lower the engine to fit the air intake I'm also aware of the exhaust situation. What I'm curious about is what about the wiring harness does it need replaced also the ECU does it need replaced and reprogrammed ? and will my 5 speed bolt to this will I need a bigger clutch ? I'm sure the clutch is bigger also would I be better off with a 3.4 instead I'm looking for more horse without buying a new car mine currently has 60k and is in great condition I recently upgraded to a spec stage 2+ clutch the response is better but I'm looking for more !! lol and I already replaced the faulty motor mount ( my assumption why the clutch went out broken motor mount was jerking the trans ) I do have e-gas also. What year engine should I look for does it matter ECU ? and Harness if they matter? should I go with the 6 speed trans can I use a six speed with the 2.7 liter for now ? any help would be gravely appriciated. and how much could I get these items for I'm new to the whole forum thing I have rebuilt cvt trans ect so the install shouldnt be rocket science for me (I hope :confused: ) lol what motor sizes will work with my car that people have already done ?
Thanks again in advance |
This is probably a good place to start
Pelican Technical Article: Boxster Engine Conversion Project - 986 Boxster (1997-04) - 987 Boxster (2005-08) |
| All times are GMT -8. The time now is 04:23 AM. |
