Old 02-21-2013, 08:27 PM   #1
More's Avatar
Empty Fuel Tank.
When the car is virtually running on empty has anyone ever noticed weird sounds in the car?
1998 Porsche Boxster 986 Convertible.
More is offline   Reply With Quote
Old 02-21-2013, 08:58 PM   #2
Skrapmot's Avatar
It's probably the sounds of soot and grime being sucked into your fuel injection.
Old 02-21-2013, 09:26 PM   #3
Why in the world would you run a Porsche, or for that matter, any car, on a virtually empty fuel tank? If you do this very often then you can say goodbye to your fuel pump, let alone the damage you can do to the injectors. They run better on the top half of the tank.
2002 Boxster S
Arctic Silver Metalic
Gray leather/Black Top
1olddude is offline   Reply With Quote
Old 02-22-2013, 06:04 AM   #4
Porsche Chick's Avatar
I thought you weren't supposed to drive a car with less than 1/4 tank, because of the fuel injection. I think it was okay in the carburetor days, but not now. I always maintain 1/4 tank minimum.
Old 02-22-2013, 08:27 AM   #5
BruceH's Avatar
Yep, a 1/4 tank is empty to me
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 02-22-2013, 09:01 AM   #6
Quite often, weird sounds emanating from a fuel tank with a low fuel level are the result of the fuel pump overheating (it is cooled by the surrounding fuel), which can lead to premature pump failure.
Old 02-22-2013, 09:02 AM   #7
recycledsixtie
recycledsixtie's Avatar
The weird sounds are coming from your subconscious saying that u are short on brains. How could you do that?
Old 02-23-2013, 12:05 AM   #8
Moderator
Don't run it empty. Fuel pumps are not cheap.
Old 02-26-2013, 02:06 AM   #9
More's Avatar
Because I was a 1000 miles away from the nearest petrol station.
Old 02-26-2013, 08:48 AM   #10
Wow. And how exactly was that helpful?
Sorry about that, More. Fortunately, rude and uncalled-for remarks like this are rare here and most people are understanding, sympathetic, and helpful. We've all learned lessons about our cars the hard way. Don't let this put you off posting again.
I will make the suggestion that you do a search before posting to make sure you're not asking a question that has already been repeatedly answered, otherwise you may deserve the flaming you get in reply.
'99 black 986
Old 02-26-2013, 08:54 AM   #11
BYprodriver's Avatar
Shaken but not stirred ? Hopefully.
Old 02-27-2013, 12:45 AM   #12
More's Avatar
Always
Old 02-27-2013, 08:02 AM   #13
Homeboy981
Homeboy981's Avatar
Not a popular choice but I'll admit I run mine in the red +20-30 miles FREQUENTLY. Not by choice. It is only because there are not always gas stations in rural areas. I go where the houses are….and sometimes being there on-time as-promised takes precedence. You don't want to blow a few thousand because you stopped for gas…unless you ARE TRULY short on brains, or rich!
I have suffered no ill effects, thus far. I do understand the risks. And there are a few times where I DID GET a SLIGHT HESITATION or miss. Most likely due to crap in the gas. That may be what the original poster was commenting about. I clean my TB frequently, so it must be the gas.
That said, you can say, "I told you so" when I burn up my fuel pump. Until then, thanks for the warning but life supersedes the fuel need sometimes.
Don't live in fear my friends, that is no way to be either!
Old 02-27-2013, 01:16 PM   #14
Nimbus117's Avatar
Who can afford the stuff anyway..
2003 Boxster 2.7L
2010 Civic Type R
