Old 11-24-2005, 05:43 AM   #1
When to replace brake pads
Hi,
I am new to my Boxster. When I am comming to a redlight from say 50 miles per hour I am hearing a Hi pitch squeel when I apply the brakes very lightly. Soon as I push harder it goes away. This does not happen everytime either. It is once in a while. I don't hear it if I am only going 20 miles per hour or so. How do you know when to replace your brake pads. I don't want to bring it to a mechanic becuase they will just tell you that they need to be replaced.
If so Do you have to buy expensive brake pads if you are not racing. I use my car just for casual driving.(Highway,to the store etc).
thanks
Joji is offline   Reply With Quote
Old 11-24-2005, 06:39 AM   #2
Brucelee's Avatar
If it were me, I would take it to a quality brake shop (NOT MIDAS ETC.) that knows Porsche.
Sounds like you need pads but an inspection is the only real way to know.
Stock pads are fine.
Good luck.
Old 11-24-2005, 08:30 AM   #3
Send a message via AIM to blinkwatt
My 99 does it as well. I would not worry about it so much as long as the brake feel is normal. I notice mine does it when its cold outside and as it heats up(longer I drive,outside temp.) it does not do it. As soon as the brake start feeling funny I would take it in.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 11-24-2005, 02:51 PM   #4
Bruce,
What stock pads do you recommend that are not that expensive.
thanks
Old 11-24-2005, 03:33 PM   #5
Pagid makes the stock ones for the 99'. For great prices and free shipping over $50(USD) go to http://www.************************************************************/index.html
Old 11-24-2005, 05:52 PM   #6
HI,
You want to make sure that you are not applying the Brakes too lightly. Doing so can Glaze the pads and they'll squeal. If it happens, apply the Brakes a little more firmly and you should be fine. Hope this helps...
Happy Motoring!... Jim'99
