-   -   Driver's side mirror removal (http://986forum.com/forums/boxster-general-discussions/43115-drivers-side-mirror-removal.html)
greenheckler 02-10-2013 10:17 AM
Hello everyone,
I want to repaint the driver's side mirror as it is in pretty bad shape.
Can someone direct me to instructions on how to remove it? I have seen some reference to the removal of the side mirror cover on the inside of the door by removing the door panel but was not sure if I had to go through all that.
ilikeching 02-10-2013 07:12 PM
As i remember there is only 3 screw inside the sidemirror cover and then the whole mirror is loose, just be careful not to loose the screw inside the doorpanel.. use magnetic screwdriver/torx.
