02-09-2013, 12:12 PM
I find that by changing my blinker fluid at indicated intervals I can avoid problems with my blinkers and keep them working smoothly.
02-09-2013, 01:04 PM
I have better luck with replacing the stock hardware with genuine blinker bolts imported from Italy.
02-09-2013, 01:08 PM
still plays with cars...
The big question is, are you using genuine Porsche blinker fluid.
Hey, and make sure you're topping off with xenon headlight fluid instead of halogen...
Sorry, OP, I couldn't resist.
Six speed 2000 Boxster S
02-09-2013, 01:25 PM
Originally Posted by James_Hatton
What, exactly, does this thing do?
02-09-2013, 01:32 PM
helps you get even fatter by not requiring you to hold the turn signal when making lane changes.
02-09-2013, 01:43 PM
You have got to be kidding me..................
02-09-2013, 05:00 PM
Have I have not heard of such a hack for our cars. It would be cool to have.
1995 Porsche C4 Cab
02-09-2013, 05:19 PM
02-09-2013, 05:39 PM
This isn't that uncommon. I had a Jetta and I now have an Audi that has this feature as standard equipment. Blinks 4 or 5 times when you push the lever in the direction and release it. Of course, you can have it lock on like all turn signals. I find I don't use it all that much.
2003 Boxster S Dark Teal
02-09-2013, 08:47 PM
So I guess the answer is no. You haven't done it and you don't know of a kit and you don't know how to do it.
Oh well, at least you guys had fun!
02-10-2013, 02:21 AM
Theoretical propagandist
For those occasions when the fluid runs low, you can always use the old analog method:
02-10-2013, 05:35 AM
The first VW Bugs had 10 inch pieces of metal built into the body at window level just behind the doors that actually dropped down, perpendicular to the body to indicate a left or a right-hand turn. They apparently weren't very helpful in signalling traffic that you were going to turn because they became known at "machs nix stix" to the Germans.
02-10-2013, 05:07 PM
There were a lot of early cars that had mechanical turn signaling devices. They are called "semaphores" and if you are old enough to remember those you probably are getting your senior discounts on everything.
02-11-2013, 05:19 AM
But what if you want to turn while signaling?
