Old 02-09-2013, 10:44 AM   #1
Climfort Blinkers
Without going into the detail/merits of it, I'd like to add one touch comfort blinkers, to my 986.
Has anybody done it and/or does anybody know of a kit for the Porsche?
Similar to:
Home Page > ES#8792 Turn Signal Comfort Module (Komfort Blinker) - 000998229A
Genuine VW 3A Passat Lupo Polo T4 One Touch Comfort Indicators Kit | eBay
Thanks,
James
James_Hatton is offline   Reply With Quote
Old 02-09-2013, 12:12 PM   #2
schnellman's Avatar
I find that by changing my blinker fluid at indicated intervals I can avoid problems with my blinkers and keep them working smoothly.
Old 02-09-2013, 01:04 PM   #3
Spinnaker's Avatar
I have better luck with replacing the stock hardware with genuine blinker bolts imported from Italy.
Old 02-09-2013, 01:08 PM   #4
still plays with cars...
BoxsterSteve's Avatar
The big question is, are you using genuine Porsche blinker fluid.
Hey, and make sure you're topping off with xenon headlight fluid instead of halogen...
Sorry, OP, I couldn't resist.
Six speed 2000 Boxster S
Old 02-09-2013, 01:25 PM   #5
Similar to:
Thanks,
James
What, exactly, does this thing do?
Old 02-09-2013, 01:32 PM   #6
tonycarreon's Avatar
helps you get even fatter by not requiring you to hold the turn signal when making lane changes.
Old 02-09-2013, 01:43 PM   #7
You have got to be kidding me..................
Old 02-09-2013, 05:00 PM   #8
Chuck W.'s Avatar
Have I have not heard of such a hack for our cars. It would be cool to have.
1995 Porsche C4 Cab
Old 02-09-2013, 05:19 PM   #9
Chuck W.'s Avatar
Old 02-09-2013, 05:39 PM   #10
dan.oneufer's Avatar
This isn't that uncommon. I had a Jetta and I now have an Audi that has this feature as standard equipment. Blinks 4 or 5 times when you push the lever in the direction and release it. Of course, you can have it lock on like all turn signals. I find I don't use it all that much.
2003 Boxster S Dark Teal
dan.oneufer is offline   Reply With Quote
Old 02-09-2013, 08:47 PM   #11
So I guess the answer is no. You haven't done it and you don't know of a kit and you don't know how to do it.
Oh well, at least you guys had fun!
Old 02-10-2013, 02:21 AM   #12
Theoretical propagandist
Eric G's Avatar
For those occasions when the fluid runs low, you can always use the old analog method:
Old 02-10-2013, 05:35 AM   #13
schnellman's Avatar
The first VW Bugs had 10 inch pieces of metal built into the body at window level just behind the doors that actually dropped down, perpendicular to the body to indicate a left or a right-hand turn. They apparently weren't very helpful in signalling traffic that you were going to turn because they became known at "machs nix stix" to the Germans.
Old 02-10-2013, 05:07 PM   #14
Spinnaker's Avatar
There were a lot of early cars that had mechanical turn signaling devices. They are called "semaphores" and if you are old enough to remember those you probably are getting your senior discounts on everything.
Old 02-11-2013, 05:19 AM   #15
But what if you want to turn while signaling?
