Old 01-19-2013, 10:56 AM   #1
Beriaan's Avatar
Exclamation Engine rpm goes down and almost die on first gear
Hi everyone,
I am new to this forum. I have a question? I have a boxter since august and the engine run fine when cold at startup in first gears but when the engine is hot i have to give a lot more gas if i dont want to stall the engine in first gear. Do anyone knows what coud be the problem? Since i dont want to go to the dealer with this yet! And it's the only bug but an anoying one.
Boxster 1999 2.5l
André :
Beriaan is offline   Reply With Quote
Old 01-19-2013, 05:04 PM   #2
clutch going bad ?
really just a guess, I know that was a symptom when my clutch was going
nicecar is offline   Reply With Quote
Old 01-19-2013, 07:16 PM   #3
Bmod986's Avatar
If you also have a slight rough idle then its probably that your throttle body is dirty.
Bmod986 is offline   Reply With Quote
Old 01-20-2013, 10:46 AM   #4
Beriaan's Avatar
If it was the clutch it would do it when its cold.
The trotle body and idle sensor have just being clean the engine run like a charm cold or warm 800 rpm and regular... Its very strange feeling when i start on a corner if i dont give some rpm the engine stall and it happen only when the engine is hot.
Tanks,
Andre
André :
Old 01-20-2013, 12:00 PM   #5
Squozen's Avatar
I'm going to guess it's a vacuum leak. Worth checking.
Squozen is offline   Reply With Quote
Old 01-22-2013, 06:25 PM   #6
Beriaan's Avatar
Tanks guys I will have a look at vacum , but when i tink of it it mit be the clutch
André :
